JDM GSR Tranny problem.....please look.
Old Nov 3, 2007 | 01:03 PM
ek9800's Avatar
Default JDM GSR Tranny problem.....please look.
My tranny started grinding pretty bad, not your orginal honda 3rd gear grind, it grinds every gear, and sometimes it won't even go into gear unless forced.
I changed the fluid and problem still occurs. People been saying it's the syhncros which i think it might be, but how can all of them go out at once.
It mainly does it at High RPM's and it either grinds or won't go into gear.
Please helpppp!!!!
Old Nov 3, 2007 | 01:05 PM
HondamanXxX's Avatar
GO GIANTS!
Default Re: JDM GSR Tranny problem.....please look. (ek9800)
Whats your clutch and pressure plate setup?
Old Nov 3, 2007 | 01:27 PM
LS-V Turbo's Avatar
Default Re: JDM GSR Tranny problem.....please look. (HondamanXxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">Whats your clutch and pressure plate setup?</TD></TR></TABLE>
kind of sounds like your clutch is not releasing all of the way and it is draging slightly on the flywheel causeing the syncros to grind check the cluthc fluid to start. and recheck your trans fluid level
Old Nov 4, 2007 | 12:28 PM
ek9800's Avatar
Exedy stage 1 clutch, and lightened flywheel.
Checked both the fluids, and they're good.
Old Nov 4, 2007 | 12:40 PM
tek9_ej2's Avatar
sounds like a clutch release problem. Does your clutch pedal feel any different? Cheapest option right now if you already checked your fluids is re-bleeding your clutch/and/or doing a master cylinder rebuild kit. Did that on mine a while back, grind went away.
Old Nov 6, 2007 | 05:11 PM
ek9800's Avatar
Default Re: (tek9_ej2)
Now sometimes when i rev it out and try to shift and push in the clutch my the rpms dont drop fast like they normally do when you push in the clutch.
My clutch pedal is starting to feel a little different
Old Nov 6, 2007 | 09:41 PM
bullyuly's Avatar
Default Re: (ek9800)
yea sound like clutch not dissengaging.. might have an internal master cylinder leak... it is cheper and better if u buy a new one then a rebuild... also try bleeding it... one thing u can doo is remove the the plastic tha covers the slave cylinder pushing the fork in front of ur motor and have some one pump the clutch a few time then hold it in while u look and see if the slave rod slowly pushes back in then u know u have a master cylinder leak...
tjhia88
May 26, 2007 06:17 AM
MilFhunter001
Jul 21, 2006 07:17 AM
No
Oct 4, 2004 04:29 AM
LSeeper
May 12, 2004 08:15 PM
TrueDC2
Oct 3, 2003 12:13 PM
