Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
is there any differences between 07 & 08 civic si
Old Nov 2, 2007 | 08:35 PM
#1 luder's Avatar
Default is there any differences between 07 & 08 civic si
performance wise
Old Nov 2, 2007 | 09:00 PM
Nighthawk R18's Avatar
Default Re: is there any differences between 07 & 08 civic si (#1 luder)
same engine.
so no.
Old Nov 2, 2007 | 10:01 PM
elohel's Avatar
Default Re: is there any differences between 07 & 08 civic si (Nighthawk R18)
^^ There's more to performance than just the engine.
But it still is true, there really is no difference (that I'm aware of).
Old Nov 2, 2007 | 10:28 PM
yed's Avatar
yed
If you want to get super technical, the tire pressure monitoring system might add some weight
If you plan on getting aftermarket rims as part of your performance needs, then maybe it's less hassle to get an 07. See the tire pressure monitor thread for more details.
Old Nov 7, 2007 | 08:54 PM
FTW's Avatar
FTW
Default Re: (yed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yed &raquo;</TD></TR><TR><TD CLASS="quote">If you want to get super technical, the tire pressure monitoring system might add some weight
If you plan on getting aftermarket rims as part of your performance needs, then maybe it's less hassle to get an 07. See the tire pressure monitor thread for more details.</TD></TR></TABLE>
yah the tire pressur monitor sensors if like the scions are on the valve stems and can be easily put onto aftermarket rims
Old Nov 7, 2007 | 09:56 PM
fg2si!kid's Avatar
New User
Default Re: (FTW)
i know for a fact that the suspension is diffrent (spring rates) there is a thread on 8thgen but i cant find it
Old Nov 7, 2007 | 09:59 PM
fg2si!kid's Avatar
New User
Default Re: (FTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FTW &raquo;</TD></TR><TR><TD CLASS="quote">
yah the tire pressur monitor sensors if like the scions are on the valve stems and can be easily put onto aftermarket rims</TD></TR></TABLE>
not all rims some are not desingnd to fit a TPMS propperly and you could have problems with them leaking and with mounting and dismounting the tire
Old Nov 8, 2007 | 06:43 AM
chinkest_raver's Avatar
Wow. Not be a dick, but search. I have seen 10 billion threads on this. Even threads that tell you the differences. As everyone said, NO from performance stance!
Old Nov 8, 2007 | 07:07 AM
builthatch's Avatar
MiG-21 superfan
performance wise? well let's just say i hope they improved the common issues of two 07 si's i've had (one essentially lemoned after nothing but problems)- popping suspension and vague third gear shifting (though helped with shifting fortification parts like comptech SS).
loudassVTEC
Mar 17, 2006 07:42 PM
BDogggUT34
Nov 28, 2005 10:39 AM
mugen92acintls
Mar 6, 2004 02:12 PM
