What could cause a "slow chug-chuging" on start up??
Old Nov 2, 2007 | 05:57 PM
SOHCMAN's Avatar
Default What could cause a "slow chug-chuging" on start up??
94lx, 184K, MT, stock in and out.
Engine is in a good state of tune except for a slighty leaking FITV, and random acting up ICV.
When I go to start the engine, after the starter stops cranking, it will almost act like its boging down and then it will spring to life after a split second of seemingly rough running...
I cleaned the EGR ports 3K ago and have been getting excellent highway mileage (30-36mpg+-)
checked the plugs, and they are kind of white with a little deposit.
oh, and no codes thrown...
sohc
Old Nov 2, 2007 | 07:49 PM
sony224422's Avatar
Default Re: What could cause a "slow chug-chuging" on start up?? (SOHCMAN)
probably time for a tune up.
Old Nov 2, 2007 | 09:30 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
whens the last time you changed your fuel filter?
Old Nov 2, 2007 | 10:38 PM
SOHCMAN's Avatar
Default Re: What could cause a "slow chug-chuging" on start up?? (I got the CD5 Jeebies!)
New fuel filter and air filter when I cleaned the EGR ports 3k ago, as well as a valve adjustment. Cap/rotor/wires/plugs are all fairly new from maybe 10k ago.
thing is it didnt do this until this week, in fact it had been running better than ever aside from the troublesom idle valves. (which is fine now except for a slight leak in the FICV)
could cold weather be the culprit?
You said you thought it could be a clogged fuel filter, perhaps my fuel pump isnt delivering enough fuel at first?
thanks for the help!
sohc
Old Nov 3, 2007 | 05:42 AM
shortlid's Avatar
I think the battery maybe on it's way out.
PhilMac23
Honda Civic (2001 - 2005)
Nov 5, 2012 11:30 AM
hondachris1994
11
Mar 24, 2008 01:02 PM
barry1me
Feb 6, 2007 11:44 AM
dub204
Aug 16, 2006 09:43 AM
dub204
Aug 15, 2006 07:42 PM
