question about hasport mounts?
Old Nov 2, 2007 | 04:05 PM
89hatcher's Avatar
Default question about hasport mounts?
i got a hasport hydro b-series EF tranny mount. i was wondering if this mount would fit on a d-series hydro tranny in an EF.
Old Nov 2, 2007 | 04:49 PM
CRX Toad's Avatar
Default Re: question about hasport mounts? (89hatcher)
No it won't work.
Old Nov 3, 2007 | 06:29 PM
keithg's Avatar
Hasport does make mounts that will work with a D-series hydro trans (92-00) into the 88-91 cars.
https://honda-tech.com/zerothread?id=2090354
The kit works with stock EF mounts or Hasport EF stock replacement mounts.
Old Nov 4, 2007 | 01:52 AM
89hatcher's Avatar
Default Re: question about hasport mounts? (keithg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithg &raquo;</TD></TR><TR><TD CLASS="quote">Hasport does make mounts that will work with a D-series hydro trans (92-00) into the 88-91 cars.
The kit works with stock EF mounts or Hasport EF stock replacement mounts.</TD></TR></TABLE>
yeah but thats hella expensive! hopefully innovative comes out with a cheaper alternative.
Old Nov 4, 2007 | 05:19 AM
keithg's Avatar
The kit is only $249 retail, so that means you should be able to find it for $199 easy and maybe even less if you shop around. Keep in mind you don't NEED the mount kit, only the hydro trans conversion kit.
Here's what I am talking about.
http://hasport.com/shop/produc...d=171
LSWagovan
Sep 6, 2010 01:40 AM
mymeatb18"
Apr 24, 2006 12:16 PM
fabworxs
10
Sep 15, 2004 08:23 AM
