need help key stuck in the switch.
ho i just need help my key is stuck in the switch i can not take it out any idea this is the second time it was stuck the first time i bought another ignition switch which included the key and the switch. i just wanna know whats keeping this problem. thanx
if you have an auto its probably the shifter interlock, i think thats what its called. Basically its telling the car its okay to take the key out, you can only get the key out in park. try wiggling the shifter and seeing if the key comes out
If you are still having problems then here is what I did to permanently fix the problem in my civic. it may be similar in your Accord:
http://www.untangible.com/blog....html
gbarrsh
Jan 29, 2003 08:31 AM
