EX transmission ratio
Old Nov 2, 2007 | 12:47 PM
hmt_eg's Avatar
Default EX transmission ratio
hey i lost fourth and fifth gear in my d15y7 and have been lookin on craigslist for that same tranny but no one has one. all i found were ex's do ex's have a longer ratio than the one that came with my car? what are the gear ratio's for EX gears. NOOB to this site thanks in advance
Old Nov 2, 2007 | 01:26 PM
Bazza's Avatar
it will have a little bit different ratio but it will work with your car... almost all d series trans line up with each motor... so you should be alright.
Old Nov 2, 2007 | 01:34 PM
skateboard_ej8's Avatar
im hench irl
Default Re: EX transmission ratio (hmt_eg)
An EX transmission will bolt up fine to you y7 block. An EX transmission has shorter gearing similar to the (s20)Si trans, but the Si transmission has even shorter gearing. When your buying a EX transmission look for the B000 stamp to make sure it is in fact an EX trans. An A000 stamp will indicate it is a CX, DX or LX trans and those are the ones with the longer gear ratios.
Old Nov 2, 2007 | 01:41 PM
B18C5-EH2's Avatar
Former Moderator
Loved
What is a D15Y7?
What year, make and model is your car?
Old Nov 2, 2007 | 01:47 PM
im hench irl
Default Re: EX transmission ratio (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">What is a D15Y7?
What year, make and model is your car?</TD></TR></TABLE>
I think he means D16y7. But more information about your car would help.
I type-O'ed an correction. D'oh.
Old Nov 2, 2007 | 01:50 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: EX transmission ratio (esco562)
I thought maybe he hit "5" instead of "6" and meant to type D16Y7.
Anyways yeah if it is a 96-00 Civic with a D16Y7 then an EX transmission will be an upgrade over the stock tranny anyways. The EX tranny has the shortest overall gearing of all D series transmissions.
Old Nov 2, 2007 | 02:54 PM
Malakai's Avatar
See here for ratios:
https://honda-tech.com/zerothread?id=2055230
Old Nov 2, 2007 | 04:27 PM
Aquafina's Avatar
Get the EX. You'll have more fun and get better mileage.
https://honda-tech.com/zerothread?id=1638578
Old Nov 3, 2007 | 10:56 PM
hmt_eg's Avatar
Default Re: (Aquafina)
sorry i messed up on post its a 92 hb d15b7
Old Feb 15, 2008 | 06:48 PM
Bunger's Avatar
Default Re: (hmt_eg)
Added the EK ratios to the trans calc:
http://www.zealautowerks.com/transcalc.php
EJtypeR
Sep 6, 2014 10:58 PM
shawnlee250
Honda Civic (2001 - 2005)
May 19, 2012 09:54 PM
96romaEK
Jul 29, 2010 10:33 AM
h1coupe
Mar 18, 2004 01:03 PM
