93 integra rear swaybar on 95 civic
it is not completly bolt on. you will need the rear lower control arms and as well. just go to the junkyard and get the rear sway bar, the rear lcas, and all the hardware. its only bolt on if your rear lcas have holes for a sway bar in them
'88-91 Civic/CRX and '90-93 Integra rear sway bars mount to the chassis differently than with later models; the DA rear bar is mounted to two brackets that hang down from the boxed frame "rails", while later model Civics and Integras use brackets that are bolted to the rear subframe. I do not know how feasible it would be to bolt the older type sway bar up to the subframe. Your best bet would be to look around under the cars and take some measurements.
auto addict
Jul 6, 2008 12:47 PM
malubawla
Suspension & Brakes
Mar 14, 2007 10:39 AM
HT Chaplain
Jan 6, 2006 11:20 AM
JDMTurboCivic11
Jan 25, 2005 07:06 PM
