HELP!!! when i was swapping springs the whole brake fell and cant realign it up to be straight
I forget the procedure, but this is a common problem. You just gotta play with the axle and pop it back in. Can't remember if the car should be in gear or not.
This is why you almost need 2 people to swap the front suspension...one to hold the assembly up and one to drop the strut. I just use a ratcheting tie-down strap to keep it upright.
Do a google search and the solution should come up.
I just hit mine with a hammer and it popped back up. It is like the joint gets hyper extended. I hit the bracket that bolts to the strut with a hammer a couple time and it popped back up. Haven't had any problems yet.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by square_1 »</TD></TR><TR><TD CLASS="quote">I just hit mine with a hammer and it popped back up. It is like the joint gets hyper extended. I hit the bracket that bolts to the strut with a hammer a couple time and it popped back up. Haven't had any problems yet.</TD></TR></TABLE>
NO! Don't hit anything with a hammer to get the axle back in. You want the teeth on the tranny or axle to get marred up? Best case is that you just damage that outer CV joint.
Finesse is key; it'll just slide back in with the proper shove and angle.
yeah, that sucks
happen to me too when i installed mine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">You just gotta play with the axle and pop it back in. Can't remember if the car should be in gear or not.
but do this ^
mine was in gear the entire time of the installation so i don't think that should be a problem
also, check every now and then, maybe a week later to see if you have a tear in your cv boot
looks like white grease inside of the wheel (common problem if you let your brake hang)
but do this ^
you have to pull it out and push it in.. kinda like having sex.. lol
but like they all say you have to play with it before you get it in....
LMFAO. You'll know when it pops back in. That **** sucks. Mine was out of gear when i was doing it. It's better to do it in gear that way it's not turning on you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by risktypeS »</TD></TR><TR><TD CLASS="quote">you have to pull it out and push it in.. kinda like having sex.. lol
</TD></TR></TABLE>hahah
that's a good way of putting it
I actually got sick of playing with it and took the stupid boot off and used my fingers to get everything to line up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Kevin. »</TD></TR><TR><TD CLASS="quote">I actually got sick of playing with it and took the stupid boot off and used my fingers to get everything to line up. </TD></TR></TABLE>
yeah it do get boring playing with it.
LMFAO
LMFAO
thanks for da help HOmies haha yea i jus played around wit it and it finally let me get it in haha
g2tegsown
Jul 2, 2008 05:58 AM
playaforiife
Suspension & Brakes
17
Dec 10, 2007 10:33 AM
rival12
Aug 10, 2004 03:55 PM
spock_rocker
21
May 20, 2004 04:56 PM
