Windshield wipers dont move on 94 Accord
Old Nov 1, 2007 | 07:27 PM
Mxrider52's Avatar
Default Windshield wipers dont move on 94 Accord
OK so yesterday the wipers worked as I used them on the way home. I go to use them this morning and get nothing. I can hear the motor running but the wipers do not move. I can just pull the wipers across the window with ease. There is nothing holding them back.
I did wash the car yesterday and had the arms up but I dont see what I could have done to prevent them from working.
I hope someone can help me out here. Thanks
Old Nov 2, 2007 | 07:11 AM
Mxrider52's Avatar
Default Re: Windshield wipers dont move on 94 Accord (Mxrider52)
Bump anyone? I know someone has to know. I need this fixed ASAP. Where do I even start at? Do I just take off the black cover and then I will see all the parts down there?
Old Nov 2, 2007 | 05:21 PM
Zerophase's Avatar
Check to see if the bolt that holds the wiper is tight.Turn on your wipers and look to see if the nut is moving.If the nut is moving but the wiper doesn't,then just tighten it.The same thing happened to me except I was driving in a torrential downpour when my wiper went out.
Old Nov 3, 2007 | 06:43 PM
Joose's Avatar
Your linkage popped off.
If you take your wipers off, then your cowl off under your wipers, you'll see that the plastic cap at the end of one of the wiper linkages is off. You could probably snap it back on temporarily. But it's worn out, and will pop off again eventually.
Blondie117
Jun 2, 2019 02:11 PM
cutsforth693doa
Apr 21, 2011 04:19 PM
Mxrider52
Dec 17, 2008 04:49 PM
Mxrider52
Nov 20, 2007 07:07 AM
