FS: Cheap! Golden Eagle Sleeved, Built B16A ERL, Ferrea, CP, Comp, Crower, Eagle, ACL,
Old Nov 1, 2007 | 05:50 PM
JorgeYaHeard's Avatar
Default FS: Cheap! Golden Eagle Sleeved Block, Built B16A Head, Head, Block or both, Make offer
I will sell block and head seperately if someone is interested!
Used and has just over 5,000 miles on it Built B16A $4000 OBO will ship via freight Charges vary depending on location. Pm me for more details or questions
Golden Eagle Sleeved and O-ringed, ERL 5 main Girdle, Align honed, Crank Balanced to 1 tenth of a gram, CP 9:1 81mm Pistons, Eagle H-Beams, ACL Bearings, ARP Main and Head Studs, Moroso Oil Pan, Ported and polished head (intake flows 302 cfm @ 24 in of water at .500 Lift Exhaust Flows 220cfm @ .500 lift), Ferrea Comp Plus Valves, Crower Dual valve springs, Crower titanium retainers, Comp Stage 3 Cams, buddy club cam gears, cut valve cover and timing cover for cam adjustment, Lightened and balanced crank pulley(only alternator), Civic Type R Lost motion assemblies, new oil pump water pump and timing belt, All OEM Gaskets, oil Sandwich adapter, ACT Heavy duty clutch with street disc, ACT prolite flywheel
Modified by JorgeYaHeard at 2:30 AM 11/3/2007
Modified by JorgeYaHeard at 10:56 PM 11/3/2007
Modified by JorgeYaHeard at 3:49 PM 11/18/2007
Old Nov 2, 2007 | 08:50 AM
Default Re: FS: Cheap! Golden Eagle Sleeved, Built B16A ERL, Ferrea, CP, Comp, Crower, Eagle, ACL, (JorgeYaH
bump
Old Nov 2, 2007 | 03:27 PM
evening bump
Old Nov 3, 2007 | 06:00 AM
morning Bump
Old Nov 3, 2007 | 03:53 PM
ttt
Old Nov 4, 2007 | 04:41 AM
ttt
Old Nov 4, 2007 | 12:05 PM
anyone?
Old Nov 4, 2007 | 05:32 PM
bump
Old Nov 5, 2007 | 02:26 PM
bump
Old Nov 6, 2007 | 03:16 AM
ttt
Old Nov 6, 2007 | 04:14 AM
fooleo's boosted's Avatar
wiil you split up I need a B16 head....I dropped a valve on my new port-flow head....ouch....
Old Nov 6, 2007 | 04:19 PM
Default Re: (fooleo's boosted)
pm'd
Old Nov 7, 2007 | 02:36 PM
bump
Old Nov 8, 2007 | 03:08 PM
bump
Old Nov 9, 2007 | 03:52 PM
still for sale!
Old Nov 10, 2007 | 04:48 AM
bump
Old Nov 10, 2007 | 07:13 PM
TYPE_LS's Avatar
bump for you
Old Nov 11, 2007 | 06:16 AM
DC-2uned's Avatar
Bump for a legit setup, I really like how meaty the sleeves are with the 81mm bore, 30 psi anyone?
Old Nov 11, 2007 | 06:57 AM
bump thanks for the support
Old Nov 12, 2007 | 06:08 PM
bump
Old Nov 13, 2007 | 05:28 PM
bump
Old Nov 15, 2007 | 03:29 AM
bump
Old Nov 15, 2007 | 02:24 PM
ttt
Old Nov 16, 2007 | 02:46 PM
buy my engine
Old Nov 17, 2007 | 01:08 PM
bump
