4 to 5 speed trans swap---89 ef hatch
Old Nov 1, 2007 | 04:01 PM
h22turbofiend's Avatar
Default 4 to 5 speed trans swap---89 ef hatch
hey guys i have a 89 hatch, i am planning on getting a 5 speed to get rid of the 4 speed, can i use the same axles or not?
thanks
Old Nov 1, 2007 | 06:08 PM
90goldhatch's Avatar
Default Re: 4 to 5 speed trans swap---89 ef hatch (h22turbofiend)
of course you can use the same axles its still d-series
Old Nov 1, 2007 | 06:17 PM
894doorDX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22turbofiend &raquo;</TD></TR><TR><TD CLASS="quote">hey guys i have a 89 hatch, i am planning on getting a 5 speed to get rid of the 4 speed, can i use the same axles or not?
thanks</TD></TR></TABLE>
Yes you can use the same axles as long as all you change is the tranny.The D series axles are all the same on the side that goes into the tranny.The difference is on the hub side.The 4 speed uses 23 spline and DX and SI use 26 spline.So as long as you don't go changing the hubs your fine.
Old Nov 6, 2007 | 05:16 AM
Default Re: 4 to 5 speed trans swap---89 ef hatch (894doorDX)
thanks
reason i asked if you go to buy axles they have a pink or yellow stripe on them, and you must order them to match....
scottso990
Nov 3, 2010 07:22 AM
trevorjohn88ef
Jan 6, 2010 09:23 PM
4door93civic
Mar 8, 2008 07:41 PM
FernEF
Oct 18, 2006 05:42 AM
cd6SiR
Dec 5, 2005 02:31 PM
