obd0 Dizzy on obd1 B series Engine
Okay so i was trying to run an obd1 dizzy with pr3 ecu like i was told by the company who sent me all this ****, that dont work so i got an obd0 d series dizzy put it on and held it there car ran. everyone said get a B sereis obd0 dizzy adn i would be fine not to come find out the b series dizzy wont bolt on either.
What do i do? bolt pattern is totaly different and i cant get two holes lined up because its hitting on vtec solinoid
wow, you are all over the place.
1st, what engine do you have and what car?
2nd, i dont belived you can run an OBD1 Dizzy on a OBD0 car. UNless you have a conversion harness. If thats the case then you should be fine.
3rd, what company are you talking about?
well what ecu do you have? you said pr3, pr3's came in both obdo and obd1
If its a obdo pr3 you need a b16 obdo dizzy end of story, like $200 from dizzy king
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy »</TD></TR><TR><TD CLASS="quote">well what ecu do you have? you said pr3, pr3's came in both obdo and obd1
If its a obdo pr3 you need a b16 obdo dizzy end of story, like $200 from dizzy king</TD></TR></TABLE>
yeah, have to run same OBD dizzy to match the ECU.
D16A6Turbo
Apr 22, 2004 11:55 PM
