Vibrations
Make sure your clutch fluid level is were it should be.
I've had the same vibration on my previous car, but that was due to the aftermarket stage 2 clutch + lightened flywheel. Something to do with Organic / Ceramic compounds in the clutch that are different from OEM.
Clutch vibration in the pedal could be your throw out bearing or your clutch beginning to slip. There's also a possibility of you riding the clutch after take off and it translates into vibration.
