d16a1 in a ef?
Old Nov 1, 2007 | 12:54 PM
skeezy's Avatar
Default d16a1 in a ef?
would my d series mounts work im pretty sure my tranny will and everything else the only thing im worried about are the mounts
Old Nov 1, 2007 | 01:01 PM
Malgerus's Avatar
Default Re: d16a1 in a ef? (skeezy)
Not worth the hassle when you can buy a ZC or a sohc vtec for very cheap these days.
Do a search, it's been covered.
Old Nov 1, 2007 | 02:10 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: d16a1 in a ef? (Malgerus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Malgerus &raquo;</TD></TR><TR><TD CLASS="quote">Not worth the hassle when you can buy a ZC or a sohc vtec for very cheap these days.
QFT.
Possible, but not worth the extra effort when easier swaps are available for dirt cheap. Especially considering that it only has a few more HP than a D16A6/SOHC ZC.
Old Nov 1, 2007 | 02:39 PM
skeezy's Avatar
Default Re: d16a1 in a ef? (wiZCo)
yea i couldnt find any locally on craigslist i dont wanna deal with the shipping and what not i found motor and tranny for 300
Old Nov 1, 2007 | 02:41 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skeezy &raquo;</TD></TR><TR><TD CLASS="quote">yea i couldnt find any locally on craigslist i dont wanna deal with the shipping and what not i found motor and tranny for 300</TD></TR></TABLE>
mounts are going to cost more than $300
Old Nov 1, 2007 | 03:21 PM
whiteknightef's Avatar
im sure there are motors around where you are!!!!
Old Nov 1, 2007 | 04:26 PM
90efhatch's Avatar
the d16a1 drop in the 1st gen rex and the same gen civics I have seen people put them into an ef but its not worth it.
Old Nov 1, 2007 | 07:15 PM
skeezy's Avatar
Default Re: (90efhatch)
yea its better than nothing though i guess
Old Nov 1, 2007 | 09:45 PM
EFh@tCh24's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90efhatch &raquo;</TD></TR><TR><TD CLASS="quote">the d16a1 drop in the 1st gen rex and the same gen civics I have seen people put them into an ef but its not worth it. </TD></TR></TABLE>
i think its worth it if u want that extra power to play with if you dont have money foe a dual cam....
Old Nov 1, 2007 | 09:50 PM
Default Re: (EFh@tCh24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFh@tCh24 &raquo;</TD></TR><TR><TD CLASS="quote">
i think its worth it if u want that extra power to play with if you dont have money foe a dual cam....</TD></TR></TABLE>
d16a1 is a dual cam.
Old Nov 2, 2007 | 07:09 AM
wiZCo's Avatar
Stouts 'n' Scotch
Don't open your mouth if you don't know what you're talking about.
OP, what engine do you have? If it's a D16A6, don't even bother with the swap, you're literally only talking a few extra HP. Plus, there's a much better aftermarket for that motor.
Old Nov 2, 2007 | 02:16 PM
skeezy's Avatar
Default Re: (wiZCo)
well my old single im pullin out has a rod knock thats the only reason im puttin the d16a1 in but i need to know what mounts i would have to use to get the d16a1 to fit in my car.
Old Nov 2, 2007 | 08:04 PM
96teggylsse's Avatar
Default Re: (skeezy)
we did this in my buddys crx... use your old tranny...which will line up the three tranny mounts.. then you have to custom make a mount for the drivers side....they dont even sell the mount so it seriously has to be custom... not a hard job at all though...if you need more info you should be able to search on googleand youll find somethig about it... good luck
Old Nov 2, 2007 | 10:53 PM
EFh@tCh24's Avatar
Default Re: (wiZCo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wiZCo &raquo;</TD></TR><TR><TD CLASS="quote">
OP, what engine do you have? If it's a D16A6, don't even bother with the swap, you're literally only talking a few extra HP. Plus, there's a much better aftermarket for that motor.</TD></TR></TABLE>
sorry fakin smart guy i read it wrong i thot he sed d16a i read it to fast unllike ur smart *** taking your time
Old Nov 3, 2007 | 09:33 AM
Malgerus's Avatar
Default Re: (96teggylsse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96teggylsse &raquo;</TD></TR><TR><TD CLASS="quote">we did this in my buddys crx... use your old tranny...which will line up the three tranny mounts.. then you have to custom make a mount for the drivers side....they dont even sell the mount so it seriously has to be custom... not a hard job at all though...if you need more info you should be able to search on googleand youll find somethig about it... good luck </TD></TR></TABLE>
The only thing about this is, you need to position the engine perfectly in the bay, and you have to worry about axle angle and all that. I suppose you could do it with string to ensure the engine is straight, but personally I wouldn't bother, especially for 118hp.
Old Nov 3, 2007 | 12:39 PM
jlicrx's Avatar
if the D16A1 is 86-87 (brown valve cover) it is only 112hp and doesn't have electronic advance ignition - will be harder to wire up the ignition - 88-89 electronic advance distributors will not bolt to the 86-87 head
Old Nov 3, 2007 | 12:59 PM
sorry fakin smart guy i read it wrong i thot he sed d16a i read it to fast unllike ur smart *** taking your time</TD></TR></TABLE>
you cant spell worth a damn. where did you go to school?
Old Nov 3, 2007 | 01:02 PM
Default Re: (STREETWERKZ)
to the OP.....
why not buy a SOHC ZC from H motors? it'll bolt right up easily, has plenty of aftermarket support, and will cost a heck of a lot less than putting the d16a1 engine in. all said and done.
Old Nov 3, 2007 | 06:18 PM
skeezy's Avatar
yea i think im going to just pull a single from the junkyard and build another frankenstein. i did have a z6 block with a y7 head. last time i ran it i beat a turbo minime runnin 10lbs and a jdm ls in a ef hatchy. plus i already know my mounts will work if i do that now i just have to sell the d16a1 or should i try to trade it for a single
Old Nov 4, 2007 | 12:30 PM
x4thGenCafe's Avatar
OF THE KINGS
yo really dont wanna do that swap. i did it in my 88 civic hatch and the motor mount on the left side of the car is always going to break after a while then the cam gears will sit on it once it does break.
not a safe swap at all
Old Nov 4, 2007 | 02:28 PM
skeezy's Avatar
Default Re: (x4thGenCafe)
yea im tryin to sell it and ima jus try to snag a single 1.5 block from the junkyard or somethin throw my y7 head on it
Old Nov 5, 2007 | 10:12 AM
Malgerus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skeezy &raquo;</TD></TR><TR><TD CLASS="quote">yea i think im going to just pull a single from the junkyard and build another frankenstein. i did have a z6 block with a y7 head. last time i ran it i beat a turbo minime runnin 10lbs and a jdm ls in a ef hatchy. plus i already know my mounts will work if i do that now i just have to sell the d16a1 or should i try to trade it for a single</TD></TR></TABLE>
Wait a second, you want to throw a Y7 head on a vtec block? Why on earth would you want to do that? If anything, get a D16A6 block and a y8 head and have a high compression mini-me.
Old Nov 5, 2007 | 04:46 PM
skeezy's Avatar
Default Re: (Malgerus)
huh?
noo a 1.5 non vtec block with a y7 head lol
Old Nov 8, 2007 | 11:46 PM
Malgerus's Avatar
Ok, but that will still make less power than a stock D16A6.
Old Nov 11, 2007 | 09:26 AM
EFh@tCh24's Avatar
you cant spell worth a damn. where did you go to school? </TD></TR></TABLE>
ur moma house!!
