Fully Built LS/VTEC with tranny and Clutch Specialties Clutch, Full wiring harness and electronics
Old Nov 1, 2007 | 12:40 PM
boarderdudeh's Avatar
Default Fully Built LS/VTEC with tranny and Clutch Specialties Clutch, Full wiring harness and electronics
Everything for your swap will be included from engine, tranny, mounts, linkage, ecu and wiring harness. Heres the Details
Engine: Ls/Vtec with less than 500 km's on it. Freshly built.
Vin: Post Wednesday Evening.
Block:
B18b
JE Forged Pistons 9:1 Compression ( you can tell what i was building for)
JE Rings
Crower Forged Rods
ARP Studs for all mains, head/block
Micropolished Crank
Remilled block and bored out .25mm
Blockgaurd
New ACL Bearings all round!
New OEM Honda Water Pump
New OEM Honda Timing Belt
New OEM Honda Thermostat
Head:
B16a
Ferrera Stainless One Piece Steel Valves
Rerrera Dual Race Springs
New Distributor
Ferrera Titanium Retainers/keepers
Cometic High Pressure Head Gasket
Adjustable Cam Gears by AEM
Re-machined and milled head.
Transmission:
All Gears have been checked and syncros are in good shape.
Clutch is Brand new Clutch Specialities with 350 ft lbs capacity.
New Axles and Mounts are for a 88-91 civic/crx. It will fit in others!
ECU: Chipped Pr3 for single O2 and no knock sensor. OBD 0 btw.
I can total up to $8000 worth of parts and machining costs.
I am asking $3200 for the setup.
call me on my cell : 604-312-6950 if interested.
FULLYBUILT2.0
Jan 27, 2009 07:44 PM
chippy
Sep 21, 2007 05:59 PM
1cleanEF
14
Jan 17, 2006 05:23 AM
yellowbananaitr
Jul 27, 2005 10:04 AM
