DA exhaust on an EF hatch
Does anyone know how to go about fitting and RSR DA catback on an EF hatch? will it fit or not? I was told I would only have to shorten it by like 6 inches or so. Is it worth getting modified or should I just get a brand new one? It is used but, I can get it for really cheap so I just wanted to weigh my options before I buy it.
PM this guy:
Taken from:
https://honda-tech.com/zero...ge=15
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman »</TD></TR><TR><TD CLASS="quote">I've done this a few times already, but the DA rear muffler section bolts right on and clear the rear sway bar just fine. I just do 1 minor thing to it and it looks exactly like the EF HKS exhaust when on the car, minus the holes drilled in a circular pattern in the tips. Quiet & stock sounding, just how I like it. Not bad when you can find a rear muffler section in perfect shape for $20 and then do the work yourself
I'll try to take better pics tomorrow before the new owner picks up the car, but it looks very clean in person.
Taken from:
Here is my CR-X also with the stock DA exhaust. You will need to cut the b pipe and the exhaust tip will also need to be shortened. I dont remember how long you have cut since its been so long ago.
4g4dcruisin
Nov 23, 2009 03:27 PM
Wilky
10
Feb 13, 2008 01:42 PM
