wilwood dynalite front brake setup need replacement rotors & pads
i have this setup on my 88 hf, got them from someone, it has 11" rotors
my question is can i use any 11" 4x100 rotors as a replacement?
anyone has using this setup pls advice, i need info.
Thanks in advance.
Thanks in advance.
I used to have an old kit (wasn't called their dynalite) and I used rotors and pads for a Corrado (think a 90 G60) which had a 4x100 rotor, same hat, and 11". It worked fine.
That sounds correct, if memory serves.
Brian at Fastbrakes sells both for that setup; you can check his website to make sure of the parts that are needed, or just buy them from him. I think his prices are pretty good.
