90 CIVIC HB
Old Nov 1, 2007 | 08:12 AM
AEC_SI_04's Avatar
Default 90 CIVIC HB
I did a dpfi to mpfi swap and i have a code 4 flashing and the rev limiter is hitting at 3000 rpms. I can't find out the problem can anyone help
thanks
Old Nov 1, 2007 | 08:33 AM
wiZCo's Avatar
Stouts 'n' Scotch
You have a code and are in limp mode, but can't figure out the problem?
Anyways, code 4 is for the crank position sensor. Check your wiring connections at the distributor and at the ECU pins.
Old Nov 1, 2007 | 10:22 AM
DustinRose's Avatar
Default Re: (wiZCo)
check the distributor wiring, or swap out distributor
worse comes to worse you can pin the wires in correctly by running some straight to the ECU, here is Hondata's pin out of OBD0 PR3 B16 ECU, but the distributors pin in the same http://www.hondata.com/techwiringpw0.html
Old Nov 6, 2007 | 08:03 AM
AEC_SI_04's Avatar
Default Re: (wiZCo)
I have 2 wires coming off hte dist. orange one and a white one going to the ECU to c1 and c2
ZCeddie586
Jun 23, 2011 09:01 PM
jgraphics
Dec 4, 2010 09:39 PM
rustbucketrex
May 27, 2007 08:31 AM
turbob18si
Dec 3, 2006 04:02 PM
Mach69
Feb 19, 2005 08:03 PM
