Suspension & Brakes Theory, alignment, spring rates....
Tokico Illuminas, Skunk 2 Coilover Sleeves, and what camber kits?
Old Nov 1, 2007 | 12:51 AM
Donboss's Avatar
Default Tokico Illuminas, Skunk 2 Coilover Sleeves, and what camber kits?
I currently have tokico illuminas, skunk 2 coilover sleeves and i was told to get just front camber kits...so would that all i need in order to drop my car?
and how is my set up?
BTW i drive a 99 accord 4dr 4cyl
Old Nov 1, 2007 | 11:46 AM
jcochran's Avatar
Default Re: Tokico Illuminas, Skunk 2 Coilover Sleeves, and what camber kits? (Donboss)
Sounds like a good setup, thats what I'm running on my DA. Search around here for info on the control arms though, on cars like my DA the camber kits limit suspension travel by about an inch because the arms are slightly longer than stock and they bottom out on the shock tower. Its fixable with a little work though.
oops sorry, Im running a Revo camber kit on mine from robearracing.com. There are other companies like Skunk2 and Blox that might make kits for your car as well, Ive heard good things about all of them.
Old Nov 1, 2007 | 12:46 PM
Donboss's Avatar
Default Re: Tokico Illuminas, Skunk 2 Coilover Sleeves, and what camber kits? (jcochran)
yeah i was just wondering if i only need front camber kits
Old Nov 1, 2007 | 01:32 PM
Tyson's Avatar
you need an alignment after lowering.
always.
Old Nov 1, 2007 | 04:16 PM
Donboss's Avatar
Default Re: Tokico Illuminas, Skunk 2 Coilover Sleeves, and what camber kits? (Tyson)
yeah im def. gonna get an alignment but i was wondering if i only need front camber kits for my 1999 honda accord 4dr 4cyl
Old Nov 1, 2007 | 04:54 PM
Tyson's Avatar
you dont need to worry about camber. fixing the toe after an alignment will give you even tire wear.
Old Nov 1, 2007 | 06:57 PM
Donboss's Avatar
oh thanks well either way i already got the front cambers so i hope a helps a bit at least
Chillinit
Suspension & Brakes
Mar 14, 2009 06:25 AM
ucd_4_life
Jan 31, 2006 04:15 PM
92integraVTECgsr
Suspension & Brakes
Aug 22, 2005 05:39 PM
Shocka1998LX
11
Dec 23, 2003 08:58 PM
SpoonCivicSedan
May 21, 2003 07:58 PM
