d15b7 y8 head?
Old Oct 31, 2007 | 06:35 PM
shizkabob3421's Avatar
Default d15b7 y8 head?
yea i just got a y8 head for my car and i have looked but not found anything but with the z6 head..like wat timeing belt would i use..also wat ecu?
thanks!
Old Nov 1, 2007 | 11:17 AM
24TEN's Avatar
PHANTOM MENACE
Default Re: d15b7 y8 head? (shizkabob3421)
Assuming you have the original equipment for the B7 (meaning you have a 92-95 Civic DX/LX) you could/should use a P28 ECU (92-95 Civic EX/Si). Reason being it's the same OBD as your current setup. As for the head, the main difference is the combustion chambers have less volume on the Y8 head which means it'll give you higher compression over a Z6 head. Other than that the install process is the same as a Z6 head but I think one of the head bolts is different. Check in the 92-00 Civic forum and look in the FAQ. There's a complete write up in there for doing the "Mini-Me" conversion.
Civic98KH
May 16, 2007 09:16 AM
4doorcivic16
May 8, 2006 06:35 AM
keepinitsimple
Feb 17, 2005 11:32 AM
shiftgear8000
Oct 19, 2004 08:30 AM
Harry_Randal
10
May 18, 2004 08:43 PM
