Wheel Hop when Launching?
Old Jun 22, 2002 | 12:04 PM
IVANITR's Avatar
Default Wheel Hop when Launching?
Hey, recently I've been going to the track and running on my Kumho Ecstas. Well it seems the track I go to is pretty sticky. Anyways, I've been getting a lot of wheel hop, crazy wheel hop actually. It feels soo damaging to the tranny and I want to avoid getting the best of it. Anyways, if I get wheel hop, would it be better suggested to launch higher or lower than that of where I get wheel hop at?
Old Jun 22, 2002 | 01:04 PM
SIK IN DA HED's Avatar
New User
Default Re: Wheel Hop when Launching? (IVANITR)
what size rims are you runnin on? what mods have you done to your suspension?
Old Jun 22, 2002 | 02:42 PM
IVANITR's Avatar
Default Re: Wheel Hop when Launching? (dlplayboy)
Just neuspeed race springs is the only suspension mod. Stock 15" ITR wheels with 195/55 tread on it.
Old Jun 22, 2002 | 03:29 PM
illusion's Avatar
i dont know why people put on springs without shocks. boggles my mind.
Old Jun 22, 2002 | 05:13 PM
SoulSurfer's Avatar
Default Re: Wheel Hop when Launching? (illusion)
Wheel hop IS going to happen especially when all youve got is springs. From what I hear, Z10 radius bars seem to work great in reducing wheel hop.
Old Jun 22, 2002 | 06:21 PM
infamousALLMTR's Avatar
Default Re: Wheel Hop when Launching? (LSDelSol)
got on word for you Z10... there contorsion bars will eliminate that.
Old Jun 22, 2002 | 06:26 PM
dmotoguy's Avatar
Default Re: Wheel Hop when Launching? (infamousRRH)
have you tried slipping the clutch instead of dropping it?
Old Jun 22, 2002 | 06:39 PM
ALLMOTOR18's Avatar
Default Re: Wheel Hop when Launching? (dmotoguy)
Slipping the clutch should help out alot...
Old Jun 23, 2002 | 01:44 PM
87CRXOwner's Avatar
these people hit it on the head just get a built up rear suspension ive even heard of someone around here trying to get rid of the rear suspension like raising the rear of the car putting more force on the front then taking some strips of metal and welding it up?? i dunno how that would work performance wise but ill post again when i find out
Old Jun 23, 2002 | 01:56 PM
dmotoguy's Avatar
Default Re: Wheel Hop when Launching? (FutureCRXOwner)
well... taking out the rear would help, but not as much as taking out the front... MMR usa makes a kit to eliminate front suspension travel
Old Jun 24, 2002 | 08:32 AM
Scary1109's Avatar
i've heard that poly motor mount bushings help a lot too, is that true?
-Scary
Old Jun 24, 2002 | 08:52 AM
PM-Performance's Avatar
Default Re: Wheel Hop when Launching? (Scary1109)
im putting em in this weekend, i got the z10's , ez motor mount bushings , and a great deal on skunk 2 coilovers(125 shipped ) . . . my wheel hop will hopfeully not exist anymore.
Old Jun 24, 2002 | 09:04 AM
IVANITR's Avatar
Default Re: Wheel Hop when Launching? (itr206)
Slipping isn't as consistant as dropping and I also have a ACT 6-Puck so slipping is kind of out. I'll consider the z10s once I find a price for them. Still, can someone help me answer my question on if wheel hop suggest a higher launch RPM?
Old Jun 24, 2002 | 09:08 AM
i got mine form B18BTURBO, viren for 356 shipped.
you can try higher rpm , but its not garunteed? what are you launching at? . . . i forgot your on street tires. . i wouldnt go any higher than like 4500 and drop it . i ran st tires one time and hit 2.2's all day and was the 1st time this was was raced , and no wheel hop .
see if that works. if not go with the motor mount inserts and then the z10 if those dont work . if noth then then do the susp up more. . . . . gotta pay to play man .
Old Jun 24, 2002 | 04:15 PM
IVANITR's Avatar
i was lauching at around 4.5k. it seemed to work really good, but it really slamed the tranny.
Old Jun 24, 2002 | 11:54 PM
slooowDX's Avatar
it'll slam your mounts up too, stripped out my motor mount bolts into my block because of bad wheelhop, i say if the car is doing it, then DONT LAUNCH IT until you fix it.
Old Jun 26, 2002 | 02:25 PM
Camber's Avatar
Default Re: Wheel Hop when Launching? (slooowDX)
the Radius arms and motor moutn inserts did not help my hop i went to the track the other day and was hopping all over the place i even snapped an axle it was hopping so bad.
Im getting better from shocks and ditching the mounts and arms
Old Jul 1, 2002 | 10:44 PM
Incognito's Avatar
Default Re: Wheel Hop when Launching? (Camber)
Try taking out some tire pressure. Might help reduce the shock.
Launching at higher RPMs and blazin tires out the hole will help, but your times might be shitty.
Old Jul 2, 2002 | 01:13 PM
dvp95's Avatar
Default Re: Wheel Hop when Launching? (Incognito)
i got $20 mounts in and they seem to work pretty good, but a good rear suspension is a must.
Old Jul 2, 2002 | 04:59 PM
DIRep972's Avatar
Smarter than you
Z10 radius arms only work as a band aid for wheel hop. I think u need some good shocks in there first. good tires, good shocks, u already have good springs. after that, radius arms.
Old Jul 7, 2002 | 01:17 AM
1 2 NV's Avatar
lower tire pressure. dont buy Z10 bars, they may work but ****, money could b better spent elsewhere. and y in the hell do u have a 6 puck clutch. god ppl go overkill on their clutches and they wonder y their trannies dont last. shock load my friend shock load, its ur enemy. get a different clutch that suits the needs of the setup u have not overkill.
Old Jul 9, 2002 | 03:16 PM
ITR21's Avatar
Default Re: Wheel Hop when Launching? (hondaatwsu)
yeah i used to get that all the time in my itr until the tires wore down .....now they spin like the dickens
The Weather Man
Jan 22, 2006 10:07 PM
ShadyBAB
Aug 8, 2005 01:49 PM
project-boosteD
May 3, 2004 03:00 PM
tnord
Mar 9, 2003 03:21 PM
pr0digy1
Nov 15, 2001 11:49 PM
