Eibach ERS Spring length ?
I just measured the length of my rear springs, which are 7" long and 650 lbs..(0700.250.0650)
Just wondering if the 8" 350 lbs springs will work or not ? (0800.250.0350)
Im using these on ground control/Koni coilvers.
Im looking to buy these:
thanks
thanks
sure they will work, honda use 8-6 inch springs in the front and rear with not a lot of issue.
If you are using GC upper mounts you might have an issue if you want the car to be really high
wont the car sit higher with a 1' longer spring ? even if the spring rates is softer ?
that means I gotta lower it down the perch more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rob. »</TD></TR><TR><TD CLASS="quote">wont the car sit higher with a 1' longer spring ? even if the spring rates is softer ?
that means I gotta lower it down the perch more...</TD></TR></TABLE>
No not necessarily, you would have to know the weight of the car.
-jack the car up (both rear wheels of the ground.
-measure from the top mount to the top of the GC threaded sleeve.
-If that distance is greater then or equal to 8 inches then you can have the car at as high as it will go as high as possible with that setup
11psiTurboSI
15
Jul 8, 2004 09:29 PM
ruthless013
May 22, 2003 10:31 AM
