*B18C EK WIRE***
Old Oct 31, 2007 | 03:53 PM
hndacord02's Avatar
Default *B18C EK WIRE***
Hey guys, I am in the process of swapping in a B18C(OBD1) into a 99 civic si(OBD2). using obd2 EWH, w/ the obd1 ecu. any links out there of what plugs are needed and what needs to be cut/resoldered, plugs changed, etc? pics would be cool!
I already have the IAB sensor wired to the ecu. distributor, injectors, starter, altenator, and IAT are all taken care of.
After comparing both of the Service Manuals, I found that these are the only sensors that get switched...
all help is greatly appreceiated!
Modified by hndacord02 at 3:52 PM 11/1/2007
Old Oct 31, 2007 | 04:33 PM
ekb16's Avatar
since your keeping it obd2 you might need to hook up the CKF sensor thats on the oil pump..obd2 motors have those and obd1 dont have that
Old Oct 31, 2007 | 07:35 PM
hndacord02's Avatar
Default Re: (ekb16)
im running the obd1 ecu as well, sorry.
Old Nov 1, 2007 | 06:41 PM
ekb16's Avatar
everything should plug up and you will have a few left over plugs since obd1 motors have less sensors than obd2..also u will get a obd2b-obd1 jumper harness for the ecu.
Old Nov 2, 2007 | 06:20 AM
hndacord02's Avatar
Default Re: (ekb16)
yea, i still gotta get one of those! thanks for reminding me!
sumoneEK
25
Nov 2, 2010 07:55 AM
kaoticstyles
Jun 20, 2008 03:30 PM
GoldCoin
Sep 6, 2006 03:37 PM
b18c4door
Oct 24, 2003 06:56 AM
wizzards581
Feb 27, 2003 05:47 PM
