Are you able to change the ruber inside the blox LCA
Old Oct 31, 2007 | 02:26 PM
sixtodc2's Avatar
Default Are you able to change the ruber inside the blox LCA
I just change my suspension and then i saw the LCA and they are shot out and torn . where can i buy a par of new rubber for the LCA
Old Oct 31, 2007 | 03:23 PM
lsvtek's Avatar
Default Re: Are you able to change the ruber inside the blox LCA (sixtodc2)
do you mean the bushing? Where the bolt goes through??
Old Oct 31, 2007 | 07:30 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sixtodc2 &raquo;</TD></TR><TR><TD CLASS="quote">I just change my suspension and then i saw the LCA and they are shot out and torn . where can i buy a par of new rubber for the LCA </TD></TR></TABLE>
You can use polyurethane bushings. Or try contacting blox to see if the OEM ones will fit. Then again, if the polyurethane fit...the OEMs should fit also.
Anyway.....if you do use rubber bushings again....MAKE SURE YOU CLOCK THEM OR YOU'LL TEAR THEM AGAIN.
Old Nov 1, 2007 | 07:17 AM
sixtodc2's Avatar
Default Re: Are you able to change the ruber inside the blox LCA (B serious)
what do u mean if i clock them they will rip !
Old Nov 1, 2007 | 07:47 AM
yadddamean!'s Avatar
you have to clock them... as in torque the bolts down while the suspension has load on it. like put a jack under the control arm and let the weight of the car down, then tighten the bolts. or just install the wheels, lower the car to the ground, and crawl under and tighten them.
those busings act like a spring in a way, and the bolts are unable to rotate in the bushing when they are tight. so if you tighten the bolts with the suspension just hanging there and let the car down, it'll rotate just the busing and tear it.
NUISANCE
Suspension & Brakes
11
Feb 23, 2010 11:53 PM
drussell4801
Suspension & Brakes
Apr 29, 2005 10:04 PM
ZeroTorque
Mar 15, 2005 08:03 PM
erebunicrx
10
Mar 12, 2005 06:45 PM
Jeff99Base
Oct 12, 2004 07:04 AM
