what oil pan for a ZC
my oil pan currently has a pin-sized hole in it. my ZC header was rubbing against the pan and it finally did its damage.
so, i need to get another oil pan and don't want to spend $400 on the moroso pan and pickup.
i know i put an HF pan on there since my Si one was bad and i think the HF might have been a bit different and caused my header to rub the pan.
what pans will fit on the car? any D series?
FYI the motor is a ZC.
thank.
thank.
thank.
thank.
If you are using the ZC exhaust manifold you will need the ZC oil pan. Otherwise any d-series oil pan should work. You can also knock a dent in it and that should correct your clearance issues.
iplaybass
Jan 22, 2004 09:14 PM
keithv
Apr 8, 2003 07:57 AM
