FS: B18B1 Longblock Part-out, Tokico HP EG/DC rear struts, MORE
This is the out-of-work while looking for a job garage sale thread! This means for you I have time to meet-up, deliver stuff, and the prices are CHEAP! I will also ship just about anything in this thread, but shipping is NOT included in prices.
B18B1 Complete Longblock Part-out. The engine had right around 140k on it. I owned and maintained the engine (from a 95 LS Integra) for a few years.
head and head parts are SOLD
Other parts for sale include...
Crank - SOLD
Rods(with bad pistons) - $30 OBO
Oil pickup - $5
Oil pump - $10
Rear water-neck - $5
Head water-neck - $5
B18a1 Crank pulley in PERFECT shape - SOLD
Timing covers $10 a piece OBO(perfect AND uncut, with hardware)
Intake manifold bracket/Alternator bracket/PS bracket - $5 a piece
Anything I forgot to list/Any and all bolts from the motor....Best Offer
Pictures of all these parts:
Pistons, covers, water pump, crank pulley, crank gear, etc.
Oil pan/pickup/windage tray
http://s20.photobucket.com/alb...9.jpg
Water-necks/oil pump
http://s20.photobucket.com/alb...8.jpg
Misc engine bolts/parts
http://s20.photobucket.com/alb...0.jpg
B18A1 Longblock Part-out. This is an obd1 block since it came out of a '93 Integra. Was a solid running motor that didn't smoke a bit.
The block has some scratches on the one center sleeve due to the cracked ringlands, but no cracks in the sleeves at all. Just needs a slight overbore to be in great shape for whatever you want to stick in it. - PENDING
Pix of block:-$50 (includes main caps and any hardware you want)
cylinder 1
http://s20.photobucket.com/alb...1.jpg
cylinder 2
http://s20.photobucket.com/alb...2.jpg
cylinder 3
http://s20.photobucket.com/alb...4.jpg
cylinder 4
http://s20.photobucket.com/alb...6.jpg
other block pics
http://s20.photobucket.com/alb...5.jpg
http://s20.photobucket.com/alb...7.jpg
The head is in great shape. Looks as though it still had the original headgasket on it with no marking indicated it was ever shaved before. The one end exhaust stud is snapped, but there are a few thread in the hold that are good. It didn't leak there when it was running.
b18a1 pr4-4 head - $50 OBO - PENDING
pics of head
stud
casting (pr4-4 same as b18b1 obd1 head)
springs with retainers with caps/bolts in-tact
valves/mating surface
cams (journals in good shape) - $10 pair
Crank - perfect shape, journals are mint- SOLD
Complete set of timing covers- $10 a piece
B18B1 crank pulley- PERFECT shape - $20 - PENDING
Oil pan/pickup/windage tray - $35
Rods- No spun bearings or heat discoloration (different part number than the b18b1 but they are identical when held side-to-side and in weight) $20
http://s20.photobucket.com/alb...3.jpg
Honda timing belt in great shape - SOLD
Rear main with new/not leaking seal- $10, Oil pump - $20 - PENDING
B18a1 upper mount - $5 Dipstick - $10 - BOTH PENDING
Breather box - $5, Crank pulley bolt/gear/key - $8, T-stat housing - $10, Pump - free - ALL PENDING
Rear Pair of Tokico HP (Blues) Struts that fit 88-91 civic/crx, 92-95 civic/del sol, and 94-01 Integra (non Type-R). They are in great shape on the outside and have zero leaks.
$75 OBO for the PAIR
Here of some pics of the rears:
They have ZERO gouges are scratches on the shafts. The seals should last a VERY long time in these.:
I took a video of these also showing they rebound perfectly and equally. I have videos of each strut, and the pair next to each other. Please PM me if you want to see that.
EX SOHC civic header. Looks to be in great shape. Came with a motor I bought. Was installed on an EG gen civic, but I think it will fit anything sohc. A great performance upgrade from the cat-on-manifold header.
$10 + shipping
FREE basketball net. Base is filled with sad, so it's damn heavy. With some ramps, we could slide it into a pickup. Pickup only. It's adjustable by height, and I think it an be standard height if you adjust it to be that high. It needs one bolt which broke when I took it apart, but you should be able to find it at home depot for under $5. It actually is only a few years old, but it did sit outside for a few years, that is why it's a little faded.
Price is FREE to someone who comes to pick it up! You will NEED a pickup to pick it up.
Base:
Backboard:
Pole (2 pieces I believe, for easy transport):
Pair of coilover springs. OBX R brand. Kinda rusty but sturdy and are the same height. 250#/in springs. I have one sleeve for them I can include.
$5 for the pair
Unripped Black OEM Honda shift-boot. Should fit an 86-89 acccord, 87-91 prelude, and the 90-93 accord/prelude. Come with the metal frame and the chrome part to clip onto the shifter.
$2
OEM springs for 94-01 Integra GSR
$25 for the SET
EG civic outer door handle. OEM black finish. Great shape, works perfect.
$8 OBO
Big pile of B series engine brackets off of b18a1 and b18b1 motors. Mostly powersteering and AC stuff, but I have the mounts off of an LS cable tranny also.
$5 or less a piece + shipping
Nuts and Bolts. I have a ****-ton of these things from Honda motors/suspension/interiors. PM me with a request and I'll mail it to you for cheap.
$cheap? + shipping
seats - sold
Intake piping from a 96 SE Integra (LS model)---SOLD
Jensen add-on tweeters with pods to mount them to your dash--SOLD
Look in my user BIO for vouches. I have been buying and selling parts on here for years and never had an issue. I am paypal verified, and will charge "real" shipping prices. I need money, not to rip someone off and ruin my reputation on here!
All parts are sold without a warranty unless otherwise stated. Parts are used unless otherwise stated.
I will ship anything as long as you cover the charges and packaging fee if it's something HUGE. I will also meet-up or deliver. My zip is PA 19504.
Bumps are always appreciated!
Modified by Danronian at 5:22 PM 11/11/2007
Modified by Danronian at 8:07 AM 11/17/2007
Modified by Danronian at 12:38 PM 11/22/2007
Crank - SOLD
Oil pickup - $5
Oil pump - $10
cylinder 1
cylinder 2
cylinder 3
cylinder 4
other block pics
pics of head
stud
$10 + shipping
Base:
Backboard:
$5 for the pair
$2
$25 for the SET
$8 OBO
$cheap? + shipping
seats - sold
For drinking tonight!
