Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
Tein Coilovers and More!
Old Oct 31, 2007 | 09:56 AM
velocitytrends.com's Avatar
Default Tein Coilovers and More!
<FONT COLOR="red">Velocity Trends</FONT> is now offering all <FONT COLOR="green">Tein Products</FONT> at the best prices on the net!
For a price please PM me, catch me on AIM at <FONT COLOR="orange">VelocityTrends1</FONT>, email me at noah@velocitytrends.com, or call the shop at <FONT COLOR="red">904.997.9903</FONT> for the HONDA-TECH PRICING.
<FONT COLOR="green">TEIN S.Tech Springs</FONT> are an excellent step towards suspension tuning. They offer approximately a 1.5 inch drop for a more aggressive appearance and increased road holding capability. Designed to be used with OEM or OEM replacement shocks. Each application is road tested in North America for the proper balance between performance and comfort. Comes with a 1 year limited warranty, spring length is guaranteed not to sag more than 5mm, and be clear of any manufacturer defects.
Additional Features:
• Chrome Vanadium SAE9254V Construction
• Progressive Spring Rate Design
• Includes Silencer Rubber on certain applications
• Green Powder Coat Finish
• Developed to be used in conjunction with OEM or OEM replacement dampers
• 1-year Manufacturers Defect and Sag Warranty
Covers over 5mm sag, breakage, deformity, and noise.
Does not cover powder coat finish and rusting.
Contents of Spring Kit:
Individual Springs × 4
Main Spring × 4
Some applications include TEIN Silencer Rubbers
Warranty Information and Bump Stop Reference Guide
2 TEIN Decals
<FONT COLOR="green">TEIN type BASIC damper</FONT> offers a high quality coilover system at an entry level price. Drivers will feel in increase in stability, and grip, while maintaining good ride quality on the street and freeway. A shortened shell case is utilized to allow for better ride and improved performance at lowered ride heights. BASIC damper is a great option for consumers wanting a simple and quality made coilover. Each application is test fitted and road tested to ensure the best possible balance between comfort and performance on the street. Includes ride height adjustment to give your vehicle a minor to major drop.
• Steel Construction
• Twin Tube internal construction
• Larger piston diameter for strut type front and rear (22mm)
• Ride Height adjustable via spring seat
• Powder coated damper body with Zinc coated threaded section
• 1-year Manufacturers Defect Warranty
• Available for Overhaul
Contents of Damper Kit:
Shock Absorber × 4
Main Spring × 4
Some applications include helper springs
Seat Lock x 12
Bumper Rubber x 4
Hook Spanner × 2
Dust Cover × 4
Instruction Manual × 1
Sticker Sheet × 1
<FONT COLOR="green">TEIN Super Street damper</FONT> kit was designed for drivers seeking improved handling on the street and at the track. A shortened shell case is utilized to allow the most piston stroke possible, which allows for a better ride at lowered ride heights, and increased grip at the track. Great for daily driving and occasion track use, whether it be at the drag strip, local circuit, or Auto-X course. Includes both ride height and damping force adjustment to allow the driver to dial in the suspension for various surface conditions.
• 16 way adjustable dampers, compression and rebound combined
Adjustable Shock Absorber × 4
Main Spring × 4
Seat Lock × 12
Bumper Rubber x 4
Hook Spanner × 2
Dust Cover × 4
Sticker Sheet × 1
<FONT COLOR="green">TEIN Super Street damper</FONT> kit was designed for drivers seeking improved handling on the street and at the track. A shortened shell case is utilized to allow the most piston stroke possible, which allows for a better ride at lowered ride heights, and increased grip at the track. Great for daily driving and occasion track use, whether it be at the drag strip, local circuit, or Auto-X course. Includes both ride height and 16 levels of damping force adjustment to allow the driver to dial in the suspension for various road conditions.
Super Street with Upper mounts adds front and rear upper mounts. The upper mounts increase steering response, and allow for <FONT COLOR="green">EDFC</FONT> compatibility. On strut type vehicles, the front upper mounts will include camber adjustment plates.
• Pillow ball upper mounts for increased steering feel
(some applications may include hardened rubber mounts instead of pillowball type)
• Upper camber adjustment on front for strut type vehicles
Main Spring × 4
Upper mount × 4
Seat Lock × 12
Bumper Rubber x 4
Hook Spanner × 2
Dust Cover × 4
Sticker Sheet × 1
TEIN has used its years of experience in various motor sports to produce a kit that provides the ultimate balance between comfort and performance. Developed for drivers seeking an aggressive coilover that can be used daily, and provide all the adjustments needed for circuit use. The <FONT COLOR="green">FLEX damper</FONT> Kit features the latest technology for all drivers who are seeking performance, and adjustability, while not giving up all ride comfort. We have incorporated separate spring perch height, and shell case length adjustment, which allows the suspension to retain more stroke and allows for more suspension tuning. The FLEX damper kit includes pillow ball upper mounts, which increase steering response; 16 levels of damping force adjustment, and is compatible with the <FONT COLOR="green">EDFC (Electronic Damping Force Controller)</FONT> for added convenience and adjustability.
• Ride Height adjustable via threaded body and spring seats
• EDFC (Electronic Damping Force Controller) compatible
• Powder coated brackets with Teflon coated shock body for heavy duty rust prevention
Main Spring × 4
Pillow ball Upper Mount × 4
Lower Spring Seat × 4
Seat Lock × 12
Bumper Rubber x 4
Hook Spanner × 2
Dust Cover × 4
Sticker Sheet × 1
The <FONT COLOR="green">MONO FLEX</FONT> coilover kit has been developed for entry-level competition motorsports and advanced street driving. Features include 16-way damping force adjustability (combined compression and rebound), a mono-tube internal design, pillowball upper mounts, and <FONT COLOR="green">EDFC</FONT> compatibility. There are independent adjustments for ride-height and spring pre-load settings for increased suspension tuning. The new Mono Flex also includes TEIN's latest technological innovation, Micro Speed Valving (MSV) system, which allows the driver to feel a greater difference in damping force adjustments. Designed and developed for consumers seeking aggressive handling on the street and at the track.
• Mono Tube internal construction
• Inverted design for strut type front and rear
• M.S.V. Technology for improved damping force adjustability
• Anodized brackets with Teflon coated shock body for heavy duty rust prevention
Main Spring × 4
Lower Spring Seat ×4
Seat Lock × 12
Bumper Rubber x 4
Hook Spanner × 2
Dust Cover × 4
Sticker Sheet × 1
Developed from actual competition TEIN was able to create a fully adjustable damper that can be easily tuned for any track and weather conditions. Super Racing Dampers utilize a full-length adjustment system to allow shock length and spring pre-load to be adjusted independently. Separate 16 - way adjustments for compression and rebound damping enable the user to fine tune for any situation. TEIN has incorporated both camber and caster adjustment into the front pillow ball upper mounts for strut type vehicles. External reservoirs on SA type dampers allow for added oil capacity. Spring rates and shock valving were derived for many years of motorsports support, to provide the ultimate damper for competition. Designed and tested for circuit use by advanced and professional drivers who are seeking complete damper tuning capability.
• 16 × 16 way adjustable dampers, compression and rebound separately adjustable
• Upper and lower camber adjustment on front for strut type vehicles
• Caster adjustment on front for strut type vehicles
• Dual EDFC (Electronic Damping Force Controller) compatible
Main Spring × 4
Seat Lock × 12
To get the most out of your Super Street and Flex Kits the EDFC is available.
The <FONT COLOR="green">EDFC (Electronic Damping Force Controller)</FONT> makes it possible for the driver to control the damping force at the touch of a button while in the driverfs seat. This is accomplished by controlling stepping motors installed on each shock absorber. Because the damping force can be controlled with such ease, the driver can adjust the suspension to suit all road/track conditions. Thus allowing the driver to fully enjoy the driving experience.
Additional Features for EDFC Control Unit:
• Compact 1/4 DIN size
• 3 Presets for Quick Adjustments
• Separately adjustable for front and rear
• Ability to use switch between 16 and 32 way adjustment
• Illumination for ease of use at night
• Variable Illumination control
• Variable Volume control
Additional Features for EDFC Motor Kit and Wiring Harness:
• Sealed rubber motor cover for improved protection
• Decreased stepping motor size for use on more applications
• Complete harness with female/ male connectors
• Extended wiring harness for ease of installation
Also available are the Tein Strut Bars.
<FONT COLOR="green">TEIN aluminum Performance Bars</FONT> are produced in two designs, round and oval. By using A6000 aluminum TEIN has been able to produce bars, which are not only lightweight but are also exceptionally rigid. The twist and flex that occurs in performance driving is reduced, therefore allowing the driver to obtain the full potential of the suspension. Features include green anodized mounting plates, polished aluminum bar, and <FONT COLOR="green">EDFC compatibility</FONT>.
• Specifically tested for each application
• A6000 Aluminum Construction
• Oval type features a two column design for increased rigidity
• Round type feature turnbuckle ends
• Anodized mounting plates
• EDFC compatible
• 3-piece design for ease of installation and removal
Contents of Performance Bar kit:
Mounting plates × 2
Performance Bar × 1
Aluminum TEIN Badage × 1
Serration nuts are included for some vehicle models
For a price please PM me, catch me on AIM at <FONT COLOR="orange">VelocityTrends1</FONT>, email me at noah@velocitytrends.com, or call the shop at <FONT COLOR="red">904.997.9903</FONT> for the HONDA-TECH PRICING. Keep in mind I can still get all the other <FONT COLOR="green">Tein</FONT> Goodies.
Old Oct 31, 2007 | 10:18 AM
polyhonda's Avatar
Default Re: Tein Coilovers and More! (velocitytrends.com)
good stuff
Old Oct 31, 2007 | 10:57 AM
You know it
Old Oct 31, 2007 | 12:40 PM
velocitytrends's Avatar
VT has a promo code on the online store for even better prices. Ask for details if you want to save some money!
Old Oct 31, 2007 | 05:22 PM
Bizump.
Old Nov 1, 2007 | 05:33 AM
Bumpers.
Old Nov 1, 2007 | 12:51 PM
Bump.
Old Nov 2, 2007 | 04:55 AM
TGIF.
Old Nov 2, 2007 | 12:48 PM
All PMs replied.
Old Nov 4, 2007 | 06:35 AM
Go Jaguars!
Old Nov 5, 2007 | 06:12 AM
TTT.
Old Nov 5, 2007 | 11:15 AM
PMs replied.
Old Nov 5, 2007 | 03:31 PM
burke420's Avatar
tein flex and ss-p for an EM2
Old Nov 6, 2007 | 04:43 AM
PM'd.
Old Nov 6, 2007 | 12:45 PM
PMs replied!
Old Nov 6, 2007 | 12:46 PM
civic121978's Avatar
Old Nov 7, 2007 | 10:52 AM
afternoon bump!
Old Nov 8, 2007 | 05:39 AM
PMs replied and orders shipped.
Old Nov 8, 2007 | 09:04 AM
PM's replied.
Old Nov 9, 2007 | 04:22 AM
Good Morning!
Old Nov 9, 2007 | 06:48 AM
PMs replied.
Old Nov 9, 2007 | 01:27 PM
TTT.
Old Nov 10, 2007 | 06:12 AM
Bizump.
Old Nov 11, 2007 | 06:16 PM
TTT.
Go Jags!
Old Nov 12, 2007 | 05:04 AM
Bump.
