My dad's Accord is STILL squeaking...
It's annoying as hell and makes the car look janky. Every bump it makes a squeak.
We've replaced the swaybar endlinks (first thing most people suggested), shocks (were blown), and the upper tophat rubber bushings. What's next? 11/13? or 14/15?
My dads accord had the same problem and it squeaked when he turned the wheel. It turned out to be the bottom ball joint on the hub
I have a 93 accord LX 4dr This care Ive abused it so much it squeaks at 3 points
My lower ball joint on the right made that noise for some reason
The hood would press against the left and right fenders when I would brake and it would squeak so loud it would make people turn to look at me
now theres a certain squeak under my car very faint but I can hear it from time to time I have no idea what causein this
you see # 2 there ?? inner sway bar bushings?? lubricated those with grease,, put grease ONLY in the inner part where it rides on the bar ,, DO NOT grease the outer part of the bushings as it might slip out of the bracket ..
Cobr547
Aug 23, 2015 08:35 AM
TheCoolNamesAre
Jul 20, 2015 03:32 PM
screamindolphin2
May 19, 2009 07:17 AM
