crx SIR spoiler template?
Old Oct 30, 2007 | 10:12 PM
specificcivic's Avatar
Default crx SIR spoiler template?
Since I have a USDM Crx and just bought a JDM SIR spoiler, I want to mount it properly b/c I have seen some really botched jobs lately. What I am wondering is if anybody has a template to mount the spoiler? or, atleast a DIY
Old Oct 30, 2007 | 10:15 PM
Fezzie's Avatar
Default Re: crx SIR spoiler template? (specificcivic)
search
Old Nov 2, 2007 | 12:26 PM
Default Re: crx SIR spoiler template? (Fezzie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fezzie &raquo;</TD></TR><TR><TD CLASS="quote">search</TD></TR></TABLE>
thanx oh smart one but everytime I search SIR spoiler or SIR template, I get 5 pg's of people either posting pics of their crx w/ spoiler or asking where to buy one. Any help is much appreciated.
Old Nov 2, 2007 | 03:27 PM
SETI20's Avatar
I always tell people to BOND the rear wing to the car.
Get automotive window sealant. Preferrably 2-part mix.
Don't go drilling holes in perfectly fine bodywork. The only thing that will come of that, is rust.
Old Nov 13, 2007 | 10:17 PM
fritter critter's Avatar
what i did was measure the rear hatch part then find out what is the middle of that, put dowm masking tape on the ends and middle, say if it measured like 42 in, then at 21 inches make a mark, i drilled holes and used sealent around the hole and it worked well for me
Old Nov 14, 2007 | 01:17 AM
ef yu's Avatar
Default Re: (fritter critter)
i would put masking tape. put the wing on, press the wing down onto the tape and you get the indent of where the holes need to be drilled.
Old Nov 14, 2007 | 05:31 AM
JustAnotherRex's Avatar
Default Re: (SETI20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 &raquo;</TD></TR><TR><TD CLASS="quote">I always tell people to BOND the rear wing to the car.
Don't go drilling holes in perfectly fine bodywork. The only thing that will come of that, is rust.</TD></TR></TABLE>
Or you can drill it and get even more rust problems like everyone else seems to suggest!
Seriously people, epoxy and sealant are your friends.
Old Nov 14, 2007 | 07:06 AM
SETI20's Avatar
BACK AWAY WITH THE DRILL BIT!
I repeat:
STEP AWAY WITH THE DRILL BIT!!!
lol
Old Nov 14, 2007 | 10:23 PM
jr94513's Avatar
are you guys serious just measure and drill some holes just use touch up pain if any paint chipped to prevent rust but prepping always makes thing come out good
Old Nov 15, 2007 | 04:48 AM
Old Nov 15, 2007 | 06:46 AM
SETI20's Avatar
Default Re: (jr94513)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jr94513 &raquo;</TD></TR><TR><TD CLASS="quote">are you guys serious just measure and drill some holes just use touch up pain if any paint chipped to prevent rust but prepping always makes thing come out good</TD></TR></TABLE>Listen to the n00b sign, and keep BS like this to yourself.
EDM crxes come with fully sealed and painted bodies. And every single time I take a spoiler off (which is dozens and dozens by now) I am greeted with rusted away mounting points.
THIS IS WHY SO MANY OEM SPOILERS DO NOT HAVE ORIGINAL MOUNTING ANYMORE!
Besides the rust, rain+holes+lowest part of hatch= you do math.
Old Nov 15, 2007 | 09:08 AM
Newark Built's Avatar
* B A N N E D *
im pretty sure my bodyshop bolted mine.
i installed the Mugen wing on my fathers TSX...for that i drilled out the holes...after i drilled i put primer and touch up paint on the exposed metal, along with a glob of clear silicone sealant around the threads.
Thank God the OEM mounting holes are marked.
went on like butta
Modified by Newark Built Kandy SiC-RX at 5:16 AM 11/19/2007
Old Nov 18, 2007 | 07:27 PM
jr94513's Avatar
DAMN you guys must not know how to do **** i use to work at a body shop and done this **** before but i guess you guys are all unable to do that simple task correctly why the f*ck would you bondo your wing it cracks and bondo is not glue it is to repair very small dings in body panels!
Old Nov 19, 2007 | 06:59 AM
SETI20's Avatar
Are you blind, or just retarded?
BOND. Not BOND-O.
Old Nov 21, 2007 | 03:16 PM
again does anybody have a template...I know that I saw one on CRX resource about 6yrs ago but it has since been deleted.
Old Nov 21, 2007 | 03:59 PM
SETI20's Avatar
Make your own.
Get some cardboard. Press the wing in it.
Presto.
But seriously. You're an idiot if you drill holes in your perfectly fine hatch.
Old Nov 21, 2007 | 04:19 PM
sr20de2's Avatar
I used the cardboard trick on mine. Then measured many times before drilling. Came out really good. Be sure to start out small with the drill bits and work your way up to the final size. Definitely use some silicone or some form of sealant around the holes to keep water out.
JeDiMaster
Jul 8, 2006 05:47 AM
Exit Music
Apr 5, 2006 03:49 PM
c0nspire
Jan 23, 2006 01:42 AM
Battle*Axe
38
Dec 14, 2005 02:19 AM
rasta420
23
Dec 14, 2002 08:09 AM
