will this throw off speedo?
Old Oct 30, 2007 | 10:02 PM
94c1v1cex's Avatar
Default will this throw off speedo?
will 245/50R-16 96 B nitto 555r dr's throw off my speedo. if so how much in which direction?
Old Oct 30, 2007 | 10:21 PM
r.wright's Avatar
Default Re: will this throw off speedo? (94c1v1cex)
u will be at least 10% too slow. i am doing the comparison based on civic sized tires
Old Oct 30, 2007 | 10:34 PM
94c1v1cex's Avatar
Default Re: will this throw off speedo? (Opossum Jenkins)
so based on that if my speedo says 20 im actually doing 18... and 30 i'm actually doing 27? basically like that?
Old Oct 31, 2007 | 01:45 AM
r.wright's Avatar
actually, yes but then you are backwards..
if the speedo reads 60 you are actually going 66
Old Oct 31, 2007 | 11:18 AM
nsxtasy's Avatar
H-T Order of Merit
Assuming from your username that you have a '94 Civic EX, then yes, they're WAY off. They will probably also rub big-time.
Your car came from the factory with 185/60-14 tires. 245/50-16 is almost 13 percent (almost three full inches) larger in diameter. If the speedo was accurate with the stock size, then if it says 60, you're actually going 67.67 mph with 245/50-16. The 16" sizes which are closest in diameter to your stock size are 195/45-16 and 205/40-16.
In the FAQ for this forum, you'll find a link to a tire size calculator where you can compare sizes to find out the differences in diameter.
Old Nov 2, 2007 | 08:19 PM
NokBlue's Avatar
http://www.1010tires.com/TireSizeCalculator.asp
here is a tire calculator. just enter your stock tire size then enter the size you want to use and it will tell you the difference.
1.5Slowmatic
Feb 3, 2010 06:12 PM
max_woe
Mar 31, 2008 09:54 PM
OldSchoolHatch
Feb 17, 2007 02:39 PM
Bok Choi
Mar 29, 2006 08:46 PM
TrueZen
Aug 31, 2005 06:01 PM
