96 4dr gsr shocks
I need new shocks on my 96 gsr sedan. any suggestions? this is strictly a work car, i want a firm comfortable ride and cheap. what do you guys suggest? Also, are 2dr and 4dr shocks the same?
Thanks
Thanks
Tokico HPs ("blues") and KYB GR-2s are both inexpensive replacements for stock dampers. If you're running stock springs, I'd recommend either of those two.
'94-01 3dr and 4dr Integras do indeed use the same dampers (which are additionally the same part as used on most 92-95 Civics) except for Type-R trim.
What makes you think you need new ones? The OEM Showa dampers don't often go bad. Are they leaking? Does the car continue oscillating more than once over bumps?
Thanks, I was thinking about both of those options. The car has about 120,000 miles now and the OEM shocks aren't completely gone but they are oscillating more than before.
ShinotakuX
13
Jul 11, 2007 03:36 PM
