Evans Tuning Shop Sale.
Old Oct 30, 2007 | 07:25 PM
Andrea's Avatar
Default Evans Tuning Shop Sale.
Manley Lightweight I Beam H22 Rods: brand new in the box. These can be used with either an h22 or h23 crank and are probably one of the best lightweight all motor rods you can get for an h-series. $500.00
Advanced Design/Ground Control Drag Coilover: Used for a season of racing. In like new condition. Comes with 800lb/in front springs and 1200lb/in rear. These are some of the best shocks on the market. Will fit 92-95 Civic and 94-01 Integra. These were used on the Evans Tuning Power Street EG last season. The shocks alone are over $400.00 each corner. Ground Control kit was additional. Independent rebound and compression adjustment on each shock. Paid close to $2000.00 for the entire combo. $1200.00
Manley retainers: used for half a season, in good condition. $100.00
Manley Valvetrain: Used for half a season, in excellent condition, comes with standard size valves, springs, retainers, and keepers. $400.00
(2 sets) RC 750cc Injectors: RC Engineering Bosch style peak and hold injectors. We can modify these to fit a Honda style rail. SOLD.
Hondata Kpro and Ecu: 2003 RSX-S ecu with Kpro. $1200.00
2000 Civic Si Tranny w/Quaife: OEM Honda 4.7 final drive -- new bearings, fresh synchros, Quaife, shifts perfectly smooth, less than 1500 miles on the new bearings, synchros, and final drive. $1500.00
Exedy Stage 2 Cerametallic Clutch w/Flywheel: Comes with the Exedy Lightweight Chromoly flywheel. For use in a b-series hydro tranny, used for less than 100 miles -- in perfect condition. $350.00
GSR Headgames Head: GSR head, ported by Headgames, has Ferrea Comp Plus valves, valvesprings, retainers, bronze guides, and valve stem seals; head comes complete with cam caps, vtec solenoid, rocker arms...basically everything but the valvecover and distributor. $1800.00
Fluidampr: Race version, b-series, used for less than 100 miles -- in like new condition. SOLD.
Skunk2 Pro3 cams: B-series, used for less than 100 miles. $400.00
Skunk 2 Cam Gears: 2 sets available (1 silver, 1 blue). Both are the tuner series. $150.00 each set.
2.0L B-series All Motor Bottom End: GSR block, GE sleeved, 86mm bore, CP lightweight X-skirt pistons (coated by Tbone), Manley lightweight I beam rods, balancedLS crank, new OEM bearings, oil pump, water pump, tensioner, main seal; comes withnew OEM Golden Eagle 86mm headgasket. $2800.00
Hasport B-series mounts: For use with EG/DC chassis; street urethane. $350.00.
Please PM with any questions. Parts can be purchased directly from our online catalog: http://www.evans-tuning.com/etstore_c285324.html.
Modified by Andrea at 7:57 PM 12/27/2007
Old Oct 30, 2007 | 07:37 PM
kptrulee's Avatar
Default Re: Evans Tuning Shop Sale. (Andrea)
Old Oct 30, 2007 | 08:25 PM
Mr.OB*GYN_Rhett's Avatar
Default Re: Evans Tuning Shop Sale. (kptrulee)
wow
Old Oct 30, 2007 | 08:55 PM
jdmek910's Avatar
Default Re: Evans Tuning Shop Sale. (Mr.OB*GYN_Rhett)
dibs on trans
Old Oct 30, 2007 | 08:57 PM
fuct.'s Avatar
clutch and flywheel for which trans?
Old Oct 30, 2007 | 09:00 PM
_HANS's Avatar
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
Default Re: Evans Tuning Shop Sale. (fuct.)
good deals
Old Oct 31, 2007 | 05:18 AM
Andrea's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuct. &raquo;</TD></TR><TR><TD CLASS="quote">clutch and flywheel for which trans?</TD></TR></TABLE>
B-series hydro...sorry. I updated it.
Old Oct 31, 2007 | 09:10 AM
Andrea's Avatar
Old Oct 31, 2007 | 02:38 PM
boosted hybrid's Avatar
Old Oct 31, 2007 | 07:26 PM
Andrea's Avatar
All PMs responded to.
Old Nov 1, 2007 | 06:28 AM
Andrea's Avatar
Old Nov 1, 2007 | 10:47 AM
Andrea's Avatar
Old Nov 1, 2007 | 06:16 PM
Andrea's Avatar
Up again.
Old Nov 1, 2007 | 06:20 PM
STREETWERKZ's Avatar
Default Re: Evans Tuning Shop Sale. (jdmek910)
bump for looking.
Old Nov 2, 2007 | 07:32 PM
Andrea's Avatar
Default Re: Evans Tuning Shop Sale. (STREETWERKZ)
Thanks.
Old Nov 5, 2007 | 04:38 AM
Andrea's Avatar
Old Nov 5, 2007 | 05:21 AM
Doostur's Avatar
Good stuff!
Old Nov 5, 2007 | 05:35 AM
Baggy Spandex's Avatar
Default Re: (Doostur)
sick stuff. evans tuning
Old Nov 5, 2007 | 06:50 AM
Andrea's Avatar
Fluidampr sold.
Old Nov 6, 2007 | 04:40 AM
Andrea's Avatar
Old Nov 8, 2007 | 07:01 AM
Andrea's Avatar
Old Nov 9, 2007 | 07:28 AM
Andrea's Avatar
Up again.
Old Nov 15, 2007 | 07:26 AM
Andrea's Avatar
Old Nov 16, 2007 | 10:38 AM
Andrea's Avatar
Old Nov 19, 2007 | 08:02 AM
Andrea's Avatar
Updated.
