91 Accord rear wheel bearing
Old Oct 30, 2007 | 07:04 PM
chris91's Avatar
Default 91 Accord rear wheel bearing
Has anyone replaced a rear wheel bearing on a '91 Accord 2dr.? I have been asking people and get all kinds of answers. thanks, Chris
Old Oct 31, 2007 | 08:51 AM
JimBlake's Avatar
Default Re: 91 Accord rear wheel bearing (chris91)
You don't say EX or LX, but it's about the same. Either way you have to take the brake off (rotor or drum). Underneath the disk (or drum) is the hub with it's 4 wheel studs. It's #1 in the picture. You have to buy it that way, can't buy JUST the bearing.
Pry off the cap #3. If you mangle it you may want to have a new one.
The spindle nut (#33) is staked into a groove on the spindle. You'll have to use a nail or a punch to bend it out so you can remove the nut. You'll see what I mean. From there it's easy.
I don't know the tightening torque for that nut, you'll want to look it up in a '91 repair manual. Then stake it into the groove & put everything else back together.
Old Nov 1, 2007 | 07:56 PM
chris91's Avatar
Thanks for your help and taking time to post a illustration, do you know if the nut is reusable?, believe it not, the bearing is cheaper at a Honda dealer then in the aftermarket. Chris
Old Nov 1, 2007 | 08:26 PM
JimBlake's Avatar
You're supposed to use a new spindle nut. I've re-used them on my car but I probablyl would not re-use them more than once. It beats em up to get staked & bent & staked again. Although that's on an extended collar without any threads.
Guteman
Jul 17, 2007 04:52 AM
cchrisj
Apr 11, 2006 08:02 PM
fitzov
Dec 3, 2005 11:58 AM
BassBoy19
Dec 13, 2004 02:06 PM
typertn
Nov 23, 2003 11:30 PM
