limp mode
* B A N N E D *
will my car be in limp mode because i havent installed the speedometer because right now the car is in limp mode and since i did the swap i havent installed the speedometer will that cause the ecu to be in limp mode ?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juanchoenuncrx »</TD></TR><TR><TD CLASS="quote">will my vtec work if i dont have the speedometer?????</TD></TR></TABLE>Yes. The speedometer is an Input from your computer coming from your VSS. Not having a speedometer will not throw your car into failure mode or "limp-in" mode. Your car is most likely in "limp" mode because something was not conmnected properly or put in right.
no....
do you not have a cluster installed?
no....
Pabs626
May 3, 2008 04:36 PM
