Anyone know how to CHANGE PISTON RINGS??
Old Oct 30, 2007 | 05:57 PM
tkewtn's Avatar
Default Anyone know how to CHANGE PISTON RINGS??
I just had to change my entire catback because it was clogged. The mechanic said that I am burning oil but there is no smoke blowing out of the new exhaust. I am using 5w30 Synthetic Mobile 1 Motor Oil in my 1995 LS Vtec. Stock pistons and stock rods in the block.
If it is bad piston rings can anyone tell me how to replace them? The more detailed the better! Thanks guys appreciate it.
Old Oct 31, 2007 | 09:45 AM
Peter Brady onlyonweekndz's Avatar
Default Re: Anyone know how to CHANGE PISTON RINGS?? (tkewtn)
i would suggest getting a Helms Manual...
Old Oct 31, 2007 | 09:55 AM
myfirstdc2's Avatar
take your motor out. then take the head off the block. then take the block apart. either hone it yourself or take it to a machine shop. best bet is let the machine do it. they will hone, deck and hot tank it for u. if u don't know what ur doing don't even try it.
dizzzane's Avatar
Default Re: Anyone know how to CHANGE PISTON RINGS?? (Peter Brady onlyonweekndz)
When you say LS VTEC do you mean you swapped a GSR or you did an LSV. Or you didn't mean to put that?
Old Oct 31, 2007 | 09:58 AM
CleanLikeJdm's Avatar
Hype-R Stalker
So did your "mechanic" diagnose this clog in your catback?
And I'm sure he wanted to change your rings while he was at it also.
Old Oct 31, 2007 | 10:03 AM
all-mtr-teg's Avatar
Sounds like your mechanic is trying to rape you
Old Oct 31, 2007 | 11:36 AM
tkewtn's Avatar
haha actually
i was driving and the car wouldn't go pass 4,000 rpm
It would bog and get stuck but when i took it to the mechanic he said it was a clogged exhaust system and when he removed the connection from the headers to the cat, i tried it out [Loud as hell] it did hit vtec and pass 4,000 rpm.
He said the clog was from burning oil. I changed the oil about 1,000 miles ago and had to add 2 quarts within about 5 days of driving it.
To the other guy
When i say it is LS Vtec [ b18b block w/ b16 head]
Anyone know about how much it would cost to take it to the shop?
Anyone have a detailed DIY information?
Old Oct 31, 2007 | 12:21 PM
95 integra's Avatar
Default Re: (tkewtn)
2 qts in 5 days is a problem. I would suggest checking for leaks as well though. It could be your valve seals as well or a few other things....but probably not if its that much oil. You probably wont find a great how-to, but you can check out c-speedracing.com if you'd like....however thats one of those things either you are confident in doing or you arent....and really the helms is the best how-to.
Old Nov 1, 2007 | 09:05 AM
Default Re: (95 integra)
im in the middle of my first build right now and it looks as though u have to put your ring gaps on at different points on the piston..if u just wanna look at what im talkin about go to hondahookup.com and they have some free helms dl...
Old Nov 1, 2007 | 09:23 AM
vtec8804's Avatar
* B A N N E D *
i have a 98gsr 54kmiles and burn about a quart of oil in a week of normal driving maybe reline a cpl gears every week?... i also use 5w30 mobile 1 full synthetic..im thinkin its my piston rings also, but i do have smoke coming out of my exhaust when vtec is engauged. id really like to know what happens to u and how you go about gettin this fixxed.
Old Nov 1, 2007 | 09:55 AM
95 integra's Avatar
Default Re: (vtec8804)
10 year old car with 54k on it? Thats some low mileage, is that carfax verified? If its not leaking anywhere, then its gotta be burning off....however the higher gears is probably just running a bit rich and not oil burning...assuming its black smoke and not white.
Old Nov 1, 2007 | 10:08 AM
I bought my 97 gsr 2 years ago with 34k miles, it didn't burn a drop of oil till i started modding it. Now it burns about a quart a month, and thats after the rebuild with fresh rings and a hone.
Old Nov 1, 2007 | 10:19 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">I bought my 97 gsr 2 years ago with 34k miles, it didn't burn a drop of oil till i started modding it. Now it burns about a quart a month, and thats after the rebuild with fresh rings and a hone.</TD></TR></TABLE>
umm why did you rebuild the motor with that few miles on it?
My car has 258K on the original engine w/ all original internals, and it goes through MAYBE 1/2 quart in 3000 miles (normal amount of oil loss w/ VTEC use I think).
Old Nov 1, 2007 | 10:23 AM
Default Re: (PatrickGSR94)
wanted cams, itr pistons, ls crank and rods, now i gotta get a stock motor to pass state referee.
Old Nov 1, 2007 | 12:36 PM
Community Builder
sucks to be in CA
Old Nov 1, 2007 | 12:37 PM
95 integra's Avatar
Clearly something went wrong with your build....it shouldnt be using oil.
Old Nov 1, 2007 | 02:41 PM
I think i bent some valves or blown HG cause im burning oil and getting a random miss cylinder 1 and 3, already swapped out entire ignition, dizzy, wires, plugs, and ecu. Still get the CEL's
Old Nov 1, 2007 | 03:32 PM
vtec8804's Avatar
* B A N N E D *
well i bought the car and two months later spun a bearing prob due to poor care before me, but now i got another gsr motor carfaxxed it and it was out of a wrecked car with 54k miles... it is burning black smoke out the exhaust when vtec is engauged.. is that also piston rings? i think im in the same boat
Old Nov 1, 2007 | 08:07 PM
tkewtn's Avatar
anyone have any tips or insight on fixing piston rings?
How much does a shop charge? Is it better to upgrade pistons and shot peen rods?
Old Nov 1, 2007 | 11:32 PM
myfirstdc2's Avatar
of course its better. depending on what piston u use. p73 or p30 would be a good start. u can even use pct if u want a really high compression. shot peen would make ur stocok rods even stronger then they already are. althought some will say stock ls rods come shot peened already. but for me if my rods are being resized for o/s p73 i would just pay the extra 50-60 bucks fro insurance.
Old Nov 2, 2007 | 12:10 AM
Default Re: (myfirstdc2)
burning smoke when vtec engaged? what color smoke is this?
Old Nov 2, 2007 | 12:13 AM
Default Re: (Peter Brady onlyonweekndz)
oh my bad.. a little .... sounds like your running a little rich iin vtec which is normal..
dc r-spec
Dec 19, 2013 10:21 AM
92integraVTECgsr
Sep 1, 2010 07:58 PM
racingant
Mar 26, 2006 02:43 AM
KingOfQB
10
Mar 4, 2006 07:30 AM
EK FLY
Oct 18, 2005 09:44 AM
