JDM fron end ?
Old Oct 30, 2007 | 04:45 PM
PinoyDelSol's Avatar
* B A N N E D *
Default JDM fron end ?
So my friend just bought a JDM front end from my other friend and he gave us a T-radiator support. How hard is it to install it in my friends 95 integra? And do you guys know any links or picture diagrams on how to do it? Thanks
Old Oct 30, 2007 | 06:00 PM
pennies_hatchie's Avatar
Default Re: JDM fron end ? (PinoyDelSol)
Pretty easy to install especially using the T support. Just drill the spot welds from his old teg (his old T support), weld in the new one. Cut the corners where the headlights go (you'll see what I mean once you start). Everything else is just bolt on.
Old Oct 30, 2007 | 06:07 PM
* B A N N E D *
Default Re: JDM fron end ? (pennies_hatchie)
really.. alright thanks.. and how do i connect the JDM headlights with his factory headlight wire harness? Because his JDM headlight wires are all spliced and cut?
Old Oct 30, 2007 | 06:46 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinoyDelSol &raquo;</TD></TR><TR><TD CLASS="quote">really.. alright thanks.. and how do i connect the JDM headlights with his factory headlight wire harness? Because his JDM headlight wires are all spliced and cut? </TD></TR></TABLE>
I was going to say that if it still had the plugs, you could get the plug and play harness from passwordjdm.com for that clean look. I guess since its splice, you would have to splice your oem one and just match up the colors on the wires.
Old Oct 30, 2007 | 08:07 PM
* B A N N E D *
simple as that huh? Okay so tommor i guess im going to start to work on my friends car, what should i take out? The headlights, radiator, front bumper, fenders, hood? What else? And can i get steps on how to take off my friends original radiator support off so i can put the T-support in. Ok Thanks man!
Old Oct 30, 2007 | 08:08 PM
* B A N N E D *
and do i really need to weld it? Or can i just drill it out and bolt it back on and get some cold putty to bond the T-support back on the cars frame?
Old Oct 30, 2007 | 08:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinoyDelSol &raquo;</TD></TR><TR><TD CLASS="quote">and do i really need to weld it? Or can i just drill it out and bolt it back on and get some cold putty to bond the T-support back on the cars frame?</TD></TR></TABLE>
Weld it. You can use bolts and screws as a temp fix, but you will want to eventually weld it.
Just take off his front end (hood, fender, bumper, lights) then drill out his old T support. Radiator doesnt need to come off, but unbolt other things on the old support such as grounds, screws, etc. Bolt/weld in the new one. Fit the new headlights and cut the corner of the chasis to fit the headlight (again you will see what you need to cut once you get there). Then rewire the headlight, put the fenders, hood, bumper back on. easy as that.
Old Oct 30, 2007 | 09:03 PM
* B A N N E D *
sweet. Alright thanks for being helpful dude. If i have further questions i will contact you! And my last question, What tools do you recommend me to use? Besides a torch. Can i use one of those propane torches as a tool to weld?
Old Oct 30, 2007 | 09:13 PM
* B A N N E D *
oh yeah, my friend also received a black dun bell bar looking thing? I'm not to sure on where that goes but do you know what im talking about? Whats the purpose for that and how would that go on the car? Thanks dude
Old Oct 30, 2007 | 09:47 PM
Naruto's Avatar
black dumbell thing? You mean...the bumper support?
Old Oct 30, 2007 | 10:03 PM
* B A N N E D *
Default Re: JDM fron end ? (Naruto)
yeah if thats what its called. Sorry if im not being specific or correct with what im explaining but this is my friends integra that i will be working on and im a civic fan, so im not really to sure about this JDM front end that i will be installing for him. But if that is the bumper support, how to i install that on? My friend that bought the JDM front end from, from my friend only gave us the hood, lights, grill, fender, bumper, T-support, and bumper support and no screws or bolts. So how will i attach the bumper support on?
Old Oct 30, 2007 | 10:10 PM
Sumslapper's Avatar
Year 3030
http://www.masetuning.com/jdmc....html
Old Oct 30, 2007 | 10:17 PM
kweezerkwee's Avatar
planning on doing my jdm front also. what would you guess recommend doing the T or using the whole radiator support. Which one is easier?
Old Oct 30, 2007 | 10:45 PM
LeArN2LiVe's Avatar
Default Re: (kweezerkwee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kweezerkwee &raquo;</TD></TR><TR><TD CLASS="quote">planning on doing my jdm front also. what would you guess recommend doing the T or using the whole radiator support. Which one is easier?</TD></TR></TABLE>
Doing the T-Bar is definitely much, much easier.
Old Oct 31, 2007 | 06:46 AM
* B A N N E D *
Default Re: (LeArN2LiVe)
Thanks sumslapper for the great article!
Old Oct 31, 2007 | 03:55 PM
* B A N N E D *
Default Re: (PinoyDelSol)
So how do i cut the Old T support off? Any outlines on where? Im alittle confused. The weblink you gave me was really good, except the fact he is doing a whole radiator and not the T-support like i am. Help.
Old Oct 31, 2007 | 04:14 PM
Just look at the support. You can clearly see the spot welds. Just use a drill and drill out the welds and the T support should come off
Old Oct 31, 2007 | 04:25 PM
Sumslapper's Avatar
Year 3030
Default Re: (pennies_hatchie)
The link i gave you is the T support. The article show a green line. That is where you cut your usdm support. The red line is where you would cut the JDM support so there is an overlap. WHen in doubt, bring it to a shop! i think most places charge anywhere from 200-400$ to do the whole radiator support
Old Oct 31, 2007 | 07:24 PM
* B A N N E D *
Default Re: (Sumslapper)
i just took pictures of my boys car and what i did so far. I need help on where to cut on the old radiator support. So when i post the pictures up you think you can edit it and circle or outline where i should cut because my T- support is somewhat different. When you see the pictures i took in 10 mins you will understand. Ok thanks guys! Oh yeah if you guys know anyone needing my boys old integra front end, he is selling it for 400 o.b.o fenders, hood, bumper, lights, bumper support. All fresh still. ok im going to post the pictures now.
Old Oct 31, 2007 | 07:39 PM
* B A N N E D *
Okay, well here are the pictures. But i just want to know where to cut my boys old Radiator support off and where i should cut the chassis so i can get the headlights to fit. Enjoy!
What part on the chassis should i cut to make the headlights fit?
And here are pictures of the old front end stuff, which is now up for sale for CHEAP!
Old Oct 31, 2007 | 07:57 PM
* B A N N E D *
oh yeah, and where can i find the JDM headlight wire harness? So i can connect my factory headlight wires to the JDM one piece headlights. I seen something on JDM but im not to sure which one it is i have to buy. And where do i run the sidemarker wires to?
Old Oct 31, 2007 | 10:15 PM
miyagi's Avatar
passwordjdm sells plug and play harnesses for both the sidemarkers AND the brown plugs on the jdm headlights.
Old Oct 31, 2007 | 10:18 PM
miyagi's Avatar
Default Re: (miyagi)
or if you don't want to spend any money, this will make life a whole lot easier
Old Oct 31, 2007 | 10:29 PM
* B A N N E D *
sweet! THANKS!
Old Oct 31, 2007 | 10:35 PM
miyagi's Avatar
