Need help with a couple of things fast!... anyone ??
Old Jun 22, 2002 | 07:04 AM
Inaniac's Avatar
New User
Default Need help with a couple of things fast!... anyone ??
How do I take the door panels completely off... my power door lock on my drivers side is jammed and i cant even push it to locked. also how does one remove a quarter panel from the front ? is it very complicated ?? anyone ?? Thanks
Old Jun 22, 2002 | 07:23 AM
00-ITR-373's Avatar
Default Re: Need help with a couple of things fast!... anyone ?? (Inaniac)
The door panels: Should be a handfull of screws to remove. Look in the door handle under a plastic tab, around the edges, etc. You should be able to remove the switches by themselves...or take out the whole switch panely. Anyway, carefully pull the door liner off. Straight off, there are maybe 8 plastic door lining clips holding the door in. Pull if off a few inches then make sure all wire harnesses are disconnected. Sorry this is a poor decscription, but it's fairly straight forward if you go slow and do what seems logical.
Old Jun 22, 2002 | 08:33 AM
Inaniac's Avatar
New User
ok and the quarter panels anyone ?
btw that helped thanks 00-ITR-373
Old Jun 22, 2002 | 08:38 AM
Matt B's Avatar
n/m
[Modified by Matt B, 12:39 PM 6/22/2002]
Old Jun 22, 2002 | 09:35 AM
Inaniac's Avatar
New User
Default Re: Need help with a couple of things fast!... anyone ?? (Matt B)
i was gonna say....
Old Jun 22, 2002 | 11:21 AM
Inaniac's Avatar
New User
ttt
Old Jun 22, 2002 | 04:47 PM
Inaniac's Avatar
New User
did someone come in here with the dumb stick or something ?
Old Jun 22, 2002 | 07:55 PM
95CoupinIt's Avatar
they are fenders how ever..not quarter panels up front..and buy a helms manual.
Old Jun 23, 2002 | 06:51 AM
Inaniac's Avatar
New User
Default Re: Need help with a couple of things fast!... anyone ?? (95CoupinIt)
heh i got one of those around here somewhere... ought to be fun trying to find it
Old Jun 23, 2002 | 07:46 AM
94HybridEX's Avatar
To remove the fenders, pop the hood...... Remove screws the hold fenders to body. Remove one bolt that holds fender to bumper and I think there may be a screw inside the door frame but I could be wrong about that.
Old Jun 23, 2002 | 06:24 PM
hondafrk's Avatar
Default Re: Need help with a couple of things fast!... anyone ?? (94HybridEx)
are you the same guy who has the post on the drivers side door lock not working unless you pull the interior door handle out. Don't bother with taking your door panel off, It is normal.
lshatch916
Jun 24, 2007 06:03 PM
todd.ludwig
May 1, 2006 02:27 AM
sony224422
Apr 9, 2006 07:31 PM
JDM EJ1 95
Mar 25, 2004 03:13 PM
onyx00
Sep 5, 2001 12:44 PM
