Powder Coating lug nuts -searched
Old Oct 30, 2007 | 11:55 AM
brandobot89's Avatar
Default Powder Coating lug nuts -searched
I have JDM ITR in champ white and i've been looking for a red of red lug nuts. All the aftermarket lug nuts like rays, works, etc have tapered ends and shoudln't be used for my wheels. I'm thinking about powder coating my oem lug nuts/locks.
What are the ups and downs? I've called a couple places and I've been quoted 85-100.
Old Oct 31, 2007 | 11:11 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Powder Coating lug nuts -searched (brandobot89)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brandobot89 &raquo;</TD></TR><TR><TD CLASS="quote">What are the ups and downs? I've called a couple places and I've been quoted 85-100. </TD></TR></TABLE>
Sounds like 85-100 reasons against.
Old Nov 1, 2007 | 12:02 PM
Default Re: Powder Coating lug nuts -searched (nsxtasy)
i mean compared to rays for $140. it's not too bad. Plus i'm using it on ITR wheels, which have the OEM ball seating. I can't use aftermarket lugs.
would the powder coat come off easily when i'm torquing down the lugs?
Old Nov 1, 2007 | 07:08 PM
Sleepy86o's Avatar
Wow 85 to 100 bucks to powdercoat lug nuts. That is overly expensive. Powdercoat can take abuse but I think after removing them a couple times the powdercoat will crack. And if you dont have a clear coat of powder on them, when you scratch it, it will turn black. I wouldn't pay more than $50. Just because I know how to powdercoat. A real good person can do it in about 1/2 hour. Maybe less.
Old Nov 1, 2007 | 07:39 PM
sleepinEP3's Avatar
its your car man and if you can afford it and want red nuts then do it. at least youll be the only one with red lugs doing it correctly on OEM wheels
Old Nov 1, 2007 | 08:41 PM
yc_dc4mar's Avatar
Default Re: Powder Coating lug nuts -searched (sleepinEP3)
just can them yourself! 4.99 Dupli FTW!
Old Nov 2, 2007 | 09:42 AM
Default Re: Powder Coating lug nuts -searched (yc_dc4mar)
You can dupli color them? Is there a way around it? A Cheaper way?
Old Jan 3, 2008 | 09:35 AM
White Smoke's Avatar
i my honda
Global Mod
I know this is old but I wanted to bring it back...
Many, many people run the tapered style nuts on OEM acorn holed wheels. I have done it for many years with no problems. Just make sure you get the wheel on there straight and you should not have any issues.
Old Jan 3, 2008 | 11:04 AM
old man neri's Avatar
Default Re: Powder Coating lug nuts -searched (White Smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">
Many, many people run the tapered style nuts on OEM acorn holed wheels. I have done it for many years with no problems. Just make sure you get the wheel on there straight and you should not have any issues.</TD></TR></TABLE>
Many people do meth as well, that doesn't mean it's a good idea.
Get the right nuts for the right wheel. Why take a chance when lug nuts are $1/each.
Old Jan 5, 2008 | 11:28 AM
Sikocivic's Avatar
I am getting my stock Ap1 wheels powdercoated. I need to find some lug nuts that will fit the OEM Honda wheels. There must be somebody that makes an aftermarket colored lugnut with the "acorn" type seat.
Old Jan 5, 2008 | 01:05 PM
Leo C's Avatar
Night Owl
Default Re: Powder Coating lug nuts -searched (Sikocivic)
There are colored OEM-style lugnuts available on ebay for a lot less than 85-100$.
Do NOT use tuner lugnuts on OEM wheels, very dangerous, take it from someone who's worked in the business.
Old Jan 5, 2008 | 01:54 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Powder Coating lug nuts -searched (Leo C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">Many, many people run the tapered style nuts on OEM acorn holed wheels. I have done it for many years with no problems. Just make sure you get the wheel on there straight and you should not have any issues.</TD></TR></TABLE>
Absolutely WRONG and UNSAFE. With the proper shaped lug nuts (i.e. same shaped seating area as the wheel), they hold the wheel on across the entire seating area. With the wrong shaped lug nuts, they only hold the wheel on around a line (a circle, actually). That circle is subjected to all the forces acting on the wheel, and it doesn't take long before the circle (usually the lug nut rather than the wheel) starts to wear down. The lug nuts loosen, and the next thing you know, you bend or snap a stud/lug and maybe lose a wheel.
If you haven't had this happen, then you've just been lucky. I've seen quite a few people who had problems as a result. And I'm not even in the business.
This is BAD ADVICE. Don't be a fool. Get the proper shaped lug nuts for your wheels - conical/tapered for aftermarket wheels, ball/spherical/radius for Honda/Acura wheels.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sikocivic &raquo;</TD></TR><TR><TD CLASS="quote">I am getting my stock Ap1 wheels powdercoated. I need to find some lug nuts that will fit the OEM Honda wheels. There must be somebody that makes an aftermarket colored lugnut with the "acorn" type seat.</TD></TR></TABLE>
Make sure they have the ball (spherical, radial) shaped seat. Be careful with the term "acorn"; a lot of the time that term is used for lug nuts which are about as long as they are wide, regardless of the shape of the seating area.
If you want black gloss lug nuts with the ball-shaped seat, look in the FAQ topic at the top of this forum and it will tell you the part number you can use to get them from any Acura dealer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leo C &raquo;</TD></TR><TR><TD CLASS="quote">Do NOT use tuner lugnuts on OEM wheels, very dangerous, take it from someone who's worked in the business.</TD></TR></TABLE>
Old Jan 5, 2008 | 03:27 PM
Sikocivic's Avatar
Thanks for the info on the black NSX lug nuts. Just what I was looking for. I did several searches but I forgot to check out the FAQ.
Old Jan 6, 2008 | 03:57 PM
burke420's Avatar
just go into the wheel threads... and youll see so many ppl using wrong lugs on their cars!
Old Jan 6, 2008 | 04:08 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (burke420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burke420 &raquo;</TD></TR><TR><TD CLASS="quote">just go into the wheel threads... and youll see so many ppl using wrong lugs on their cars!</TD></TR></TABLE>
As Matt said, so very well...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old man neri &raquo;</TD></TR><TR><TD CLASS="quote">Many people do meth as well, that doesn't mean it's a good idea.
Get the right nuts for the right wheel. Why take a chance when lug nuts are $1/each. </TD></TR></TABLE>
gixxer508
Jul 19, 2010 04:24 PM
EM-One
Audio / Security / Video
Nov 27, 2007 07:15 AM
dc2r_j
Jun 13, 2006 10:09 PM
.BigSexy
Feb 15, 2006 03:58 PM
vietnameeh
Nov 12, 2005 11:33 PM
