6th gear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elohel »</TD></TR><TR><TD CLASS="quote">50+ MPH and I'm usually in 6th.</TD></TR></TABLE>
Same here.
Same here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jiro »</TD></TR><TR><TD CLASS="quote">So is it bad to be on 6th gear if its less than 50 mph?</TD></TR></TABLE>
Anything below 45 mph or about 2k RPMs I personally think is bad for the engine. It just 'sounds' like the engine is straining, and I'm sure it's not easy on the engine to pulling 3000 lbs at 1800 RPMs. I read somewhere that a scanguage also noted that gas consumption at 45 MPH was best in 5th gear.
Anything below 45 mph or about 2k RPMs I personally think is bad for the engine. It just 'sounds' like the engine is straining, and I'm sure it's not easy on the engine to pulling 3000 lbs at 1800 RPMs. I read somewhere that a scanguage also noted that gas consumption at 45 MPH was best in 5th gear.</TD></TR></TABLE>
yeah 3000 RPM is optimal good gas economy. and no choking on the engine. i read that somewhere too. there was a popular post about a month or two ago
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stein »</TD></TR><TR><TD CLASS="quote">I drop it into 6th around 40mph.</TD></TR></TABLE>same here
1-2-4-6
gas saver here
1-2-4-6
gas saver here
Mikey3000
Sep 24, 2007 08:17 AM
Kyles ej1
100
Aug 6, 2004 07:16 PM
