Slight amount of rust on top of sleeve.....
Old Oct 30, 2007 | 09:32 AM
mitsuman's Avatar
Default Slight amount of rust on top of sleeve.....
Well a couple weekends ago i finally put my motor in. i was not able to put the head on. This weekend i was able to finish putting the axles in along with the shift linkage and all suspension.
I had covered the cylinders so no crap got in there, i took the towels off and i noticed that the top(not the top inside, the top that meets the gasket) has some surface rust. I want to put the head on tonight and am wondering what i can do to remedy this.
Steel wool?
copper spray?
Thanks guys.
Old Oct 30, 2007 | 10:16 AM
B20luda's Avatar
Default Re: Slight amount of rust on top of sleeve..... (mitsuman)
try taking a light sand paper to it... or use some type of scotch brite....thats what i would do. Dosent mean its right tho, im sure honda-tech has some procedure for this
Old Oct 30, 2007 | 11:20 AM
Muckman's Avatar
Moderator in Chief
I had the same problem. I used a scotch brite pad and went with the grain. You dont want to remove material ruining the flatness.
Old Nov 2, 2007 | 10:23 AM
mitsuman's Avatar
Default Re: Slight amount of rust on top of sleeve..... (Muckman)
just for the record, i used steel wool, worked great!
check out my build for updates....
boosted91crx
Aug 17, 2009 06:04 PM
mrbsponge
Nov 30, 2008 08:43 AM
TooManyTickets
Jun 2, 2007 10:26 PM
Toda Built
Oct 4, 2004 04:20 PM
crxONcrack
Mar 17, 2003 08:36 AM
