Accord problem, H22A swap, don't start
Old Oct 30, 2007 | 09:25 AM
Root79's Avatar
Default Accord problem, H22A swap, don't start
2000 Accord coupe CG4
Before F20B6 now h22A jdm.
No cell. Injectors working there is fuel and spark. Distributor check no problem. When ignite it seems like wrong firing.
What could the problem?
Old Oct 30, 2007 | 09:50 AM
hatchling37's Avatar
Default Re: Accord problem, H22A swap, don't start (Root79)
May sound stupid, but are your plugs in the correct position?
Old Oct 30, 2007 | 10:15 AM
nitttrous's Avatar
honda prelude motors are very easy to mess up on wiring your vest bet is to check yor firing order make shure you have compression and that your timming is currect the firing order is 1 3 4 2 and any other questions just post them
Old Nov 2, 2007 | 07:51 AM
Root79's Avatar
Default Re: Accord problem, H22A swap, don't start (nitttrous)
Play with distributor and firing order. It's OK. Check plugs too, they are good. Will check the timing belt. That's my 20th H22 swap. First time such problem.
CHARGERS_FAN_09
Jan 16, 2012 05:24 PM
4drH22Accord
Aug 16, 2009 06:01 AM
delirious1520
Dec 23, 2005 08:00 PM
SiRTifiedacc
Aug 29, 2004 07:42 PM
jdmcgill
Nov 29, 2003 07:55 AM
