GSR GOIN IN MY EF HATCH.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roberts88 »</TD></TR><TR><TD CLASS="quote">like timing belt and manifold. someone told me i might have problems changing it after the motor is in....</TD></TR></TABLE> Timing belt, water and oil pump arn't a bad idea before you swap it in your car.
Don't forget to pound your frame in just below the driver sside shock tower for alternator clearance. Also be sure you aren't using the gsr driver side engine bracket.you have to use an obd0 ls or b16a bracket or the mount won't line up. Also lol, on the front crossmember where the tranny mount would be on a stock d series that bracket has to be removed
how much do oil pumps usually run? and the guy whos swaping the motor is recommending that i get the cross member for the lower subframe he highly recommends this. It allows for the headers to clear properly.
Well, yes. Changing those while the engine is on a stand is infinitely easier than doing it once it's in the bay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roberts88 »</TD></TR><TR><TD CLASS="quote">how much do oil pumps usually run? and the guy whos swaping the motor is recommending that i get the cross member for the lower subframe he highly recommends this. It allows for the headers to clear properly.
Depends on which oil pump you're running. Usually around $100 or so. I would recommend a traction bar if you're going turbo. Otherwise, leave it as is if it's been cut and re-welded for a B-series motor header.
what type of wiring are you going to have obd0 or obd1? I highly recommend upgrading to obd1. Front crossmember is recommended but not needed if you are running the stock header. Good luck with the project, i have a b18c right now and man do i love it!
Spookygeek
May 3, 2008 09:59 PM
