Nooob Question i know
Old Oct 30, 2007 | 06:32 AM
goku335's Avatar
Default Nooob Question i know
I know this is a Noob question but what is the difference between a stage 1 clutch a stage 2 clutch and a stage 3 clutch? I have been hearing a lot of different things and i just want to know because im getting ready to do a motor swap H22
Old Oct 30, 2007 | 08:32 AM
Twixle's Avatar
ate my pixel
Default Re: Nooob Question i know (goku335)
Stage 1 is your basic everyday clutch. They use organic materials to make up the disc, and can handle stock amounts of power from a car. Stage 2 clutches typically use cerametallic material for friction, which can withstand significantly more power than the stage 1. The cerametallic has a higher coefficient of friction so it's more resistant to clutch slip. The stage 3 usually uses a sprung disc or puck, which, depending on the springs used, can withstand godly amounts of power. These are typically used in drag cars, higher end sports cars, etc.
With an H22 swap into the accord I'd think that you would be safe to stay with the stage 1 unless you're going forced induction. If like taking off hard and drive agressively, you might want to do the stage 2 just to get a better feel.
the.hamburglar
Aug 11, 2008 05:26 AM
Hharrishonda
Jun 27, 2008 11:56 AM
99fbpem1
Jul 2, 2007 08:52 PM
gotalcoholmanup4
Nov 15, 2005 06:21 AM
