tranny grind?
Old Oct 29, 2007 | 09:04 PM
VtecVillan's Avatar
Default tranny grind?
I found another problem since my motor swap. Swapped in a d15b vtec with an ex tranny into 94 civic cx hb. I just bled the clutch again tonight, went to start it up and let out on the clutch (while in neutral) and it started to grind. Almost as if it wasn't going into gear. I am pretty sure the tranny doesn't have a linkage adjuster does it?
Old Oct 29, 2007 | 09:26 PM
Syndacate's Avatar
Default Re: tranny grind? (VtecVillan)
Is it resisting hard or just grinding like a bitch?
Does it do this in 1st and reverse?
Is it drivable in any way?
Old Oct 29, 2007 | 09:32 PM
VtecVillan's Avatar
I didnt want to try driving it with noise. Let me go and see what it does real quick, if it engages or not. brb
Old Oct 29, 2007 | 09:36 PM
VtecVillan's Avatar
Ok, So I put it in first with the clutch in, then drove forward and back...nothing. But when I leave it in neutral with the e-brake on and let off the clutch, then the noise happens
Old Oct 29, 2007 | 09:40 PM
Syndacate's Avatar
Default Re: (VtecVillan)
Sounds like you might be losing an input shaft bearing.
Does it shift fine into all gears with the car off?
Old Oct 29, 2007 | 09:45 PM
VtecVillan's Avatar
Yes, it shifts fine while the car is off.
Old Oct 29, 2007 | 09:48 PM
Historyg's Avatar
totally agree with him, does the noise go away when you let go of the clutch and go away when you hit the clutch
Old Oct 29, 2007 | 09:50 PM
VtecVillan's Avatar
when I shifted the noise went away. Only when I was in neutral letting go of the clutch, is when it grinded
Old Oct 29, 2007 | 09:52 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Historyg &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you might be losing an input shaft bearing.
totally agree with him, does the noise go away when you let go of the clutch and go away when you hit the clutch </TD></TR></TABLE>
As much as I'd like to say it's the input shaft bearing, I don't think it is.
It wouldn't be all quiet once it's in 1st, he said it is. My input shaft bearing went and it was loud as hell when you were in gear and riving. It seems as though the clutch isn't disengaging enough, the first step, as he did correctly would be to bleed the clutch, but obviously that didn't help. Check to make sure there's no air in the clutch lines. Test for a bad throwout bearing (take it up the road, if you hear a ticking noise with ur foot lightly on the clutch, that's most likely the cause).
Though I must say I'm pretty stumped.
Old Oct 29, 2007 | 09:53 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecVillan &raquo;</TD></TR><TR><TD CLASS="quote">when I shifted the noise went away. Only when I was in neutral letting go of the clutch, is when it grinded</TD></TR></TABLE>
Oh, heh, yeah, now that sounds like the ISB (input shaft bearing).
Change it out, no biggie, and if you can't do it, it's not exactly labor intensive at a garage. It does require you to drop the trans, but I think it's most likely the cause.
Historyg's Avatar
sounds like a input shaft gone bad, well its not as bad as you think, you can drive you car, but its not suggested, i did it for two years with a bad ISB, but you never know when its going to crap out, well to make sure its your isb, first off are you sure its a grinding noise, not just a anoying noise when you let go of the clutch grinding and ISB noise are totally different, check if you car shifts in all gears with the car on and then hit me back
project-boosteD
Transmission & Drivetrain
Jul 31, 2010 01:52 PM
amej8
Apr 7, 2008 04:14 PM
H.A.R.T b16a1crx
Sep 4, 2004 11:07 PM
member32
Feb 3, 2003 10:30 AM
