95 accord
Old Oct 29, 2007 | 07:45 PM
EgK2o09's Avatar
Default 95 accord
Im about to pick up a 95' honda accord with a swapped h22,its automatic..it is running a check engine light i was wonder where the malfunction indiacator light is located...also the drive 4 light is blinking i have no ideal what that is,the car runs kinda rough...if any could help i appreciate it. thank you
Old Oct 29, 2007 | 08:28 PM
JimBlake's Avatar
Default Re: 95 accord (EgK2o09)
MIL is what Honda 'officially' calls the CEL. Same thing.
Blinking D4 lamp is kinda like a CEL for the tranny. It'll blink its own code while the CEL is blinking its.
Old Oct 29, 2007 | 09:25 PM
EgK2o09's Avatar
Default Re: 95 accord (JimBlake)
do u know where the cel is located in the cd6...also how would i have the tranny code checked
Old Oct 29, 2007 | 11:21 PM
Twixle's Avatar
ate my pixel
Passenger side, below the glovebox. There should be a blue plug with 2 wires going to it, run a jump wire between those two and then turn the key to acc. position. Count the blinks and that will give you the CEL code.
Old Oct 29, 2007 | 11:51 PM
EgK2o09's Avatar
Default Re: 95 accord (Twixle)
thank you for your help twixle . would u happen to know how i could find out why the d4 is blinking?
Old Oct 29, 2007 | 11:54 PM
Twixle's Avatar
ate my pixel
Naw, I always had a 5 spd so I don't know much about the TCU and how it works. Well **** I'm bored, gimme a sec and I'll look it up.
Old Oct 30, 2007 | 12:06 AM
Twixle's Avatar
ate my pixel
Alright. Well it says that one condition that can cause poor performance of the AT is poor engine performance, so the D4 light could simply go away when you fix the CEL.
Otherwise, it says to remove the console to get to the two plugs below the shifter handle. You'll then want to check for continuity with the shifter in the D4 position. Here's an improv illustration of the continuity you want to look for, I can scan the page later if you're still having trouble.
So the plug is pinned as follows: (X will indicate no pin in this location)
1---2---X---X---3---4---5
X---6---7---8---9---10--11
This is obviously the larger plug, don't worry about the smaller one. So you want to have the shifter in D4, and check for continuity in pins 1, 9, and 5. So hook up a test light and it should be getting volts in the pins I listed.
Before you go to all that trouble be sure and warm up the car and check the ATF level, also make sure it's not leaking ATF.
Old Oct 30, 2007 | 12:47 PM
EgK2o09's Avatar
thank you for your time and help...im not getting the car till next week..i will get back to u if i have anymore trouble.
Nealva
Mar 27, 2017 12:29 PM
moarlow95ex
Jan 16, 2014 04:00 PM
One Low Accord
May 30, 2008 04:35 PM
