Are 5 lug brakes worth it? *opinions wanted*
Old Oct 29, 2007 | 06:57 PM
sk8shorty012's Avatar
Default Are 5 lug brakes worth it? *opinions wanted*
So currently I own a 99' Civic Si. Stock brakes (with the rear disc). I know there's ways to upgrade the brakes to ITR / CTR status while keeping the 4 lug (re-drilled front 11.1" rotors and 10.2" 02-03 si rotors in the rear). I want to stay 4 lug to keep the rims I have now, so 5 lug isn't an option. I have 23mm rear sway and 26mm front sway. It's a daily driver and used for some spirited canyon runs / auto-x. My question is, are the type-r brakes worth it / needed? Or will the stock brakes suffice for what I'm doing with some good / pads rotors?
Just want some opinions on whether it'd be money well spent or if I should use it elsewhere.
Old Oct 29, 2007 | 07:01 PM
BlueIntegraBoy's Avatar
Default Re: Are 5 lug brakes worth it? *opinions wanted* (sk8shorty012)
Using 92-96 Prelude VTEC rotors (redrilled) and Prelude VTEC/ITR calipers, you can have the same brakes but 4-lug.
Old Oct 29, 2007 | 07:08 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Are 5 lug brakes worth it? *opinions wanted* (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Using 92-96 Prelude VTEC rotors (redrilled) and Prelude VTEC/ITR calipers, you can have the same brakes but 4-lug.</TD></TR></TABLE>
pm brakeexpert
I'm sure you can get the same braking power for 1/4 of the price. And a lot less hassle.
Old Oct 29, 2007 | 07:09 PM
hmtcrxsir's Avatar
in my opinion its more of a cosmetic issue than actual performance. Unless you were talking about the bigger brakes and caliper for stopping power then thats another story,. But some would argue that 5 lugs is safer. haha **Shrugs**
Old Oct 29, 2007 | 07:30 PM
I actually already know about the front setup. Thats what im asking, is it worth it to do the 4 lug type r brakes, or just leave the em1 brakes (for my application listed above)?
Should I put out the dough, or is it not worth it and money can be better spent?
bmoua's Avatar
the EM1 stock brake setup is well off, get some quality rotors (doesnt have to be drilled/slotted) with good pads and brake hoses. If your really serious about upgrading brakes then i would run 98-01 accord calipers up front and rsx/ep3 rear cailper/rotors in the rear.
Old Oct 30, 2007 | 09:19 AM
Default Re: (bmoua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmoua &raquo;</TD></TR><TR><TD CLASS="quote">If your really serious about upgrading brakes</TD></TR></TABLE>
thats what im asking. Should I be serious about them?
Here's a better way of putting it. The 23mm rear sway compared to the 13mm rear sway makes a VERY distinct difference and will affect the outcome of auto-x type events. I'm saying, if you compare em1 brakes to type-r brakes, are they worth the money to get or will the stock em1 brakes suffice for track use?
Old Oct 30, 2007 | 09:25 AM
Bazza's Avatar
id def upgrade your brakes... keep 4 lug the way blueintegraboy said... its probly your cheapest/easiest way.
Old Oct 30, 2007 | 09:45 AM
Good, these are the kind of opinions I wanted. The only thing is, I don't like the re-drilled front rotors. There's no 4x100 11.1" rotor?
Old Oct 30, 2007 | 09:49 AM
Malakai's Avatar
jesus christ man! how can ppl tell u if its needed or not. They dont know how u are driving in these events?! If your fading or not getting enough stopping power then upgrade. Y not try ur car out first then decide if its needed or not? Most of the time all u really need is a good rotor and some quality pads.
Old Oct 30, 2007 | 09:50 AM
well, I mean aside from the driver, brakes do have their limits.
Old Oct 30, 2007 | 10:02 AM
1992Si's Avatar
Default Re: (Malakai)
Good point.
I know it's not the same but I have ask rota if the car needs bigger brakes? He say no. the car stops fine from 146mph. All we've done is Brembo sloted blanks and a good pad.
Granted he's not stopping over and over. But the brakes have to work the First time for him. The engine gets turned off after he hits the brakes.
Old Oct 30, 2007 | 10:27 AM
Default Re: (sk8shorty012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8shorty012 &raquo;</TD></TR><TR><TD CLASS="quote">Good, these are the kind of opinions I wanted. The only thing is, I don't like the re-drilled front rotors. There's no 4x100 11.1" rotor?</TD></TR></TABLE>
PM BrakeExpert. I am sure he has sold lots of redrilled rotors and can attest to the quality.
Old Oct 30, 2007 | 01:00 PM
Aquafina's Avatar
Default Re: Are 5 lug brakes worth it? *opinions wanted* (hmtcrxsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hmtcrxsir &raquo;</TD></TR><TR><TD CLASS="quote">in my opinion its more of a cosmetic issue than actual performance. Unless you were talking about the bigger brakes and caliper for stopping power then thats another story,. But some would argue that 5 lugs is safer. haha **Shrugs**</TD></TR></TABLE>
Yeah, look at me hard park with my 5-lug.
Yes it is worth it if you track your car. Since you just do autocross and stupid canyon runs, just go with the 4-lug big brake DIY deal. Check with the SCCA rules though. 5-lug gets you an auto boot to SM, I'm guessing the 4-lug big brake DIY deal does the same.
Good pads and tires should be good enough for you.
Old Oct 30, 2007 | 01:02 PM
97Ej6mike's Avatar
I find 5-lug to be more of an aesthetic issue than a technical one. Oh and it attracts theifs too, just another thing that can attract unwanted attention. Just my $0.02
Old Oct 30, 2007 | 01:15 PM
Aquafina's Avatar
Default Re: (97Ej6mike)
lol.
Big brakes, beefier hubs, not having to pit in if you brake a stud on track, ready to use rotors available less than 30 minutes away from most any track in the country... But I'm one of the people who doesn't give a damn what my car looks like, so I digress.
Old Oct 30, 2007 | 01:46 PM
b17eg's Avatar
Default Re: (Aquafina)
go to fastbrakes.com they have good set-ups for good prices. if u have any ?'s about anything they are pretty quick to reply.
Old Oct 30, 2007 | 02:06 PM
I AM WEASEL's Avatar
Is there an advantage of using redrilled 92-96 prelude vtec rotors rather than redrilled ITR rotors?
Old Oct 30, 2007 | 03:22 PM
Default Re: (-DC4-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -DC4- &raquo;</TD></TR><TR><TD CLASS="quote">Is there an advantage of using redrilled 92-96 prelude vtec rotors rather than redrilled ITR rotors?</TD></TR></TABLE>
Maybe just cheaper
Old Oct 30, 2007 | 03:54 PM
Aquafina's Avatar
Default Re: (BlueIntegraBoy)
Redrilled ITR would be weaker. 5 holes plus 4 new holes.
Old Oct 30, 2007 | 05:41 PM
so heres a question to those with the 4 lug type r brakes, what dust shields are you running, if any?
Old Oct 30, 2007 | 06:03 PM
Cheez-It's Avatar
i run the ITR 5-lug conversion on my 99 hatch and it's a world of difference from the rear disk conversion.
Old Oct 30, 2007 | 06:34 PM
b17eg's Avatar
Default Re: (Cheez-It)
<U></U> FASTBRAKES.COM!!!
Old Oct 31, 2007 | 05:18 AM
D50boy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cheez-It &raquo;</TD></TR><TR><TD CLASS="quote">i run the ITR 5-lug conversion on my 99 hatch and it's a world of difference from the rear disk conversion.</TD></TR></TABLE>
Ditto. The ITR brakes are awesome. The 5th lug is a PITA, but the brakes behind them are nice.
Old Oct 31, 2007 | 07:02 AM
audiko4's Avatar
Default Re: (D50boy)
If you want the 5 lug look then its worth it, but if you want bigger brakes then just do the prelude upgrade. On my setup I also got the legend dual piston calipers.
