wiring help please?
need help w/ wiring on dizzy. 91 Ls swap into 91 dual point civic. i am using my stock harness but the Ls dizzy connector is different from civic harness dizzy connector. does anyone know how to wire this up. appreciate the help thanks
first off you need to convert your car to MPFI, here is how to do that, its not that complicated. http://www.angelfire.com/d20/h....html
once you do that then wire the dizzy. if its an obd1 dizzy here is how you do it.
https://honda-tech.com/zerothread?id=1349052
TwoKSiR
Oct 30, 2007 12:47 PM
