Yes i tried search first, couldn't decide what to use?
Old Jun 21, 2002 | 11:29 PM
hondacivic4g's Avatar
Default Yes i tried search first, couldn't decide what to use?
I'm building a D16Z6 w/ T25 looking to boost 10-12 psi.
For now, I'm going to run a mini-me set up, until the D16Z6/turbo project is complete.
My problem is what diameter exhaust piping to run for the D16Z6/turbo project?
And is there one that will work efficiently for both set ups?(mini-me & D16Z6/turbo)
The main focus is the Turbo project.
So, if there isn't one that works for both,then i'll just come up with some thing cheap and efficient for the Mini-me.
Thanks
Old Jun 21, 2002 | 11:34 PM
DJ KrunchyKracker's Avatar
Default Re: Yes i tried search first, couldn't decide what to use? (hondacivic4g)
im not a mechanic but i would recommend like 2.5 or maybe 3 because of the 10-12 of boost
Old Jun 21, 2002 | 11:54 PM
B16CRX's Avatar
Default Re: Yes i tried search first, couldn't decide what to use? (TheRZA28)
Turbos like big exhausts. A 3" Thermal turbo exhaust would be good.
Old Jun 22, 2002 | 04:47 AM
keithv's Avatar
there really isn't one that will work at the optimal level for both setups. NA setups won't like exhaust piping bigger than 2.5" (unless you have a B20 or something similiar to that). the turbo app. will like a 3" exhaust so it can flow.
so, you could go with 2.5" piping and hurt the NA app some and the turbo app some. its just a compromise.
Old Jun 22, 2002 | 05:02 AM
USDM 4G VTEC's Avatar
go to the cheapest muffler shop and have them make u a 2.25" aluminum custom made piping. that should be cheap
then after the turbo. get a 3" piping catback sytem......
Old Jun 22, 2002 | 06:28 AM
89 CRX SI's Avatar
Default Re: Yes i tried search first, couldn't decide what to use? (JDM EF9)
or get 3" to the first bend then taper it to 2.5" mendrel through the rest of the system................mmmmmmm oh yeah thats what i have..................
jdmdseries
Nov 26, 2007 07:28 PM
icehayden
Jun 21, 2007 10:16 AM
integracivic94
Jun 8, 2003 02:50 PM
hondacivic4g
Jun 24, 2002 10:54 PM
