JAVOedge Accessories: HTC to 3.5mm, Samsung to 3.5mm, Male to Male Cable
Old Oct 29, 2007 | 04:55 PM
JAVOedge's Avatar
Default JAVOedge Accessories: HTC to 3.5mm, Samsung to 3.5mm, Male to Male Cable
JAVOedge releases HTC 11 Pin to 3.5mm Stereo Male to Male Coiled Cable
JAVOedge's HTC 11 Pin to 3.5mm Stereo Coiled Cable is all you need to listen to music on your HTC 11 pin port equipped device with any stereo that features a 3.5mm aux-in port.
Ever wanted to listen to MP3s on your HTC device in your car? If you vehicle's stereo has an aux-in port then this cable is right for you! Eliminate the need to buy a stereo adapter and 3.5mm male to male cable separately, this cable is all you need.
The perfect case, the perfect look! One of the best case in the market today!
* Specifically designed to work with your HTC 11 pin port equipped Smartphones / Pocket PC Phones
* Coiled cable keeps the cord short and gives you extended length when needed
* Gold Plated 3.5mm Tip, Durable, compact, and lightweight
* Works great with any stereo equipped with 3.5mm aux-in ports
* A must have for HTC 11 pin port equipped Smartphone owners
Compatible with:
AT&T/Cingular 8525, T-Mobile Dash, T-Mobile Wing.
See more HTC JAVOedge accessories by JAVOedge.com
JAVOedge releases Samsung Port to 3.5mm Stereo Male to Male Coiled Cable
JAVOedge's Samsung Port to 3.5mm Stereo Coiled Cable is all you need to listen to music on your Samsung device with any stereo that features a 3.5mm aux-in port.
Ever wanted to listen to MP3s on your Samsung device in your car? If you vehicle's stereo has an aux-in port then this cable is right for you! Eliminate the need to buy a stereo adapter and 3.5mm male to male cable separately, this cable is all you need.
* Specifically designed to work with your Samsung port equipped Smartphones
* A must have for Samsung Smartphone owners
Compatible with:
Samsung SYNC A707, Cingular Blackjack i607, D807, UpStage M620, M610, T509, T519, T629, T809, U740.
See more Samsung JAVOedge accessories by JAVOedge.com
3.5mm to 3.5mm Stereo Male to Male Retractable Cable
JAVOedge's 3.5mm to 3.5mm Stereo Retractable Cable is all you need to listen to music on your MP3 device with any stereo that features a 3.5mm aux-in port.
Ever wanted to listen to music on your MP3 player in your car? If you vehicle's stereo has an aux-in port then this cable is right for you! Eliminate the need to buy converters and extension cables separately, this cable is all you need.
* Specifically designed to work with your handheld MP3 Players
* Retractable cable keeps things clean, extend and retract as needed
* A must have for iPod/MP3 player owners
Compatible with:
All Apple iPods, iPhones, Sony PSP, Nintendo DS, any other 3.5mm audio jack equipped device
See more JAVOedge accessories by JAVOedge.com
AllCityNemo
Sep 19, 2008 06:03 PM
cua0
May 10, 2007 05:16 PM
mike93eh
May 20, 2005 06:20 AM
