Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Civic Suspension question
Old Oct 29, 2007 | 02:46 PM
HuskerHybrid's Avatar
Default 2001 Civic Suspension question
How do you drop out the rear strut assemblies? There doesn't seem to be an access location for the upper strut nuts. Or are there nuts that need to be removed similar to the fronts? Do you just drop out the rears? I can't seem to remove the rear strut assemblies.
Old Oct 29, 2007 | 02:51 PM
oddmut's Avatar
Default Re: 2001 Civic Suspension question (HuskerHybrid)
in the trunk behind the seats in the corners under the carpet is the screw for the top of the struts. Should be about 2 or 3 screws. Forgot. The bottom is pretty simple.
Old Oct 29, 2007 | 02:53 PM
Default Re: 2001 Civic Suspension question (oddmut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oddmut &raquo;</TD></TR><TR><TD CLASS="quote">in the trunk behind the seats in the corners under the carpet is the screw for the top of the struts. Should be about 2 or 3 screws. Forgot. The bottom is pretty simple.</TD></TR></TABLE>
Right, but the nuts arent accessible, there's a giant piece of sheet metal in the way.
Old Oct 29, 2007 | 02:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HuskerHybrid &raquo;</TD></TR><TR><TD CLASS="quote">
Right, but the nuts arent accessible, there's a giant piece of sheet metal in the way.</TD></TR></TABLE>
This is a sedan by the way.
Old Oct 29, 2007 | 03:10 PM
oddmut's Avatar
I drive a sedan too. There is enough room to work with back there. Just remove the carpetting and you'll be fine.
Old Oct 29, 2007 | 08:58 PM
1llmatic's Avatar
New User
its tight in there but you can access the nuts.
Old Oct 30, 2007 | 05:26 AM
Nighthawk7thGen's Avatar
Default Re: 2001 Civic Suspension question (1llmatic)
And while you're back there removing rugs...just take all of em out anyways! Im a fan for a hard, cold floorpan. Saves ya bout 20lbs...not like that matters...but who needs em
chriseg6
Honda S2000
14
Aug 5, 2006 06:22 AM
philibuster
Acura TSX
Nov 28, 2005 02:23 PM
RA73DR
Nov 16, 2005 08:33 AM
fullracecrxsi87
Oct 12, 2005 05:14 PM
03ephatch
Aug 11, 2004 10:09 PM
